What can I test with a Micronta 22-171A digital multimeter
What does a micronta 22-171A test or what is it used for ,I'm not sure stereo components or kitchen appliances
It is a Digital Multimeter for testing voltage, continuity, ohms and milliamps. The engineer will be very upset to lose it, so give them a ring.
micronta 22 171A Google Search
Dec 31, 2016 | Kitchen Ranges
How do I use a micronta 22-212 ?
Unless you have a clamp-on ammeter, you can't use a multi-meter to test AC current. You can test volts or ohms, however. If you want to see if your heating element is still good, turn off the power, disconnect the wires going to the heating element then measure the internal resistance of the element. If it's "infinity" then it's open and burned out. For a 10kW heating element at 240V it should be about 6ohms.
Sep 22, 2014 | Water Heaters
Schematic radio shack?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sep 02, 2014 | Televison & Video
Use of micronta 22-167
Is this an old Multimeter? I would try a Google search and search the Radio Shack website for a manual.
May 06, 2014 | Radio Communications
Micronta 22164 talking meter says low battery
Could be an internal memory battery that would be separate from the normal power batteries.
Jan 26, 2014 | Cars & Trucks
I need a manual for a Micronta 22-185A multimeter online.
Hi racqbell...
Go to the following webpage and download your user manual for the Micronta 22-185 multimeter.
Please take time to rate me
Aug 18, 2011 | Garden
How to connect to test amperage on a digital multimeter
go to click on digital multitester cp7677, scroll to bottom of page and download the user manual pdf file for detail amperage tests. The manual is free.
Jan 05, 2010 | Actron Digital Multimeter Tester
162 people viewed this question
