SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
SOURCE: My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
SOURCE: vostro 200 shuts down and power light stays a
The steady orange Power LED is an indication of a motherboard issue. If the system has any expansion cards (Expansion Video, Audio, NIC etc) try removing them and using the integrated card and see if issue stops, if so replace the associated card.
If no cards, or no change, issue is most likely the Motherboard
