Question about Cell Phones
Is any place in clintonmiss where can charge up for me
    Master:
  • 469 Answers
Carpal tunnel syndrome is a nerve condition of the wrist and hand. It can cause discomfort, numbness and tingling. It's brought on by performing repetitive hand motions, this kind of as typing. Here We Are Going To Evaluate The Logitech Wi Fi Trackball M570 Computer...
Posted on Dec 31, 2016
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
IPod overheating then will not charge
you need to go and get the battery replaced, it has been fried
Feb 16, 2014 | Apple iPod touch
Esteryates69@yahoo.com
If you placed the order, contact the vendor with whom you placed the order. If you didn't place the order, contact the bank for information about the charge. FixYa has no access to information about your private financial transactions.
Nov 17, 2013 | Computers & Internet
Not charging
Here are some troubleshooting ideas:
1) Clean your battery contacts with a pencil eraser, both on the radio and the charger (gently).
2) Have your radio turned off when placed on the charger.
3) Does the light on the charger come on when you place the battery on the charger?
4) Try another battery on the same charger and see if it will charge a different battery.
5) Try the known good battery on this radio and see if the radio functions correctly with a known good battery.
6) Try a different charger with the questionable battery and see if you can get it to charge.
7) Be certain the insert in the BPR40 charger is turned the correct direction for the type of battery you have. When inserted correctly the rails should guide the radio into place, placing the external charge contacts on the radio against the charge contacts of the charger.
8) Check the date code on your battery, if more than 2 years old, replace it.
Best regards.
Oct 05, 2011 | Motorola Mag One BPR40 Two Way Radio
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
Does a 920-T have an automatic shutdown mode which
TomToms do not turn off the charging, regardless of whether they are ON or OFF. It should ALWAYS be charging. When you place the GPS on the dock, it should have a small green LED lighting up on the lower right. That's the indication that it is charging.
Please, verify and report back in case you need further help
Mar 27, 2010 | Tomtom Go 920T GPS Receiver
GPS unit won't charge when placed on cradle and plugged in wall
You may have to replace your battery, these go faulty often, even though they seem OK.
Feb 07, 2010 | Garmin Forerunner 305 GPS Receiver
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
