Question about Boating
Suzuki boat motor will nor operate under load. It is fine without load
    Top Expert:
  • Boating Master
  • 48,461 Answers
Could be a damaged propellor
Posted on Dec 31, 2016
I have a 140 Suzuki 4 stroke and a small oil leak.. where are the coolant lines in the engine please
go google and type in--- workshop manual for suzuki 140 hp 4 stroke outboard and there are manuals that are available on different site
the manuals will show where the lines are
one site --servicemanualspro.info--- has a pdf down load link
Dec 02, 2015 | Boating
How to adjustment jets on a suzuki 115 hp outboard 1989
I am not familiar with the Suzuki brand but short of small motors (under 25 hp) most if not all motors by 1989 are fixed jet and not adjustable. If fuel is the problem, cleaning it the answer.
Jul 07, 2014 | Light Outboard Motor Boat Bass Fishing...
Suzuki outboard boat motor 250 hp four stroke 2012, good motor?
Excellant! Just hope you're not putting it on a light boat... that thing could take flight if you're not carefull. Suzuki can build motors - others are copying thier racing designs.
Jun 13, 2012 | Suzuki Motorcycles
Boat won't plane idles fine runs with throttle open without hesitating doesn't build up speed
Check your prop hub. If you have a larger motor there are rubber bushings in the hub which can slip. This is a safety feature like shear pins. You may need to rebush the prop.
You also need the proper length motor for your transom. And you need enough power to overcome the drag and weight of a loaded boat. Check and see if the angle settings for the locking pin will provide an upward thrust to the hull and not plow the hull down.
Mar 12, 2010 | Boating
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in...
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Jun 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Motor looses power under load 1989 90 hp mariner pro series
if coppresion is fine then you have a electrical problem more than likley your power pack cdi is gettin hot and breaking down
Jun 16, 2009 | Boating
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
