No sound on tv
TV is electrifies ev19
Electroview tv ev19 no sound
hi,
please check to make sure none of your cables are loose.give them a waggle while tv is turned on.if this does not help.check to make sure you haven't put mute on.good luck.
Feb 03, 2014 | Computers & Internet
How to turn on shutter sound on electrify m
Have you turned up your phone volume as well?
Dec 28, 2013 | Motorola Mobility Electrify
Tv randomly loses pictrue but not sound when watching
May be you need replace the lamp.
Time life aprox 3000 hours
If the picture is dark or don`t show picture, but you get sound, try replace the lamp
Is easy. You can find it in www.Amazon.com I recommend you buy Electrified brand.
Sep 16, 2011 | Televison & Video
Where can I get a Lamp Ballast for my HP MD5020n TV?
http://shop.ebay.com/i.html?_nkw=hp+md5020n&_armrs=1&_from=&_ipg=
Nov 04, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Hi I have a 2004 sony kp-51ws520 projection tv ser# 8028189 it will not turn on only the red led stand by light blinks and i must unplug the tv to make it stop. This tv has never had any work done Thank...
It sounds like your bulb is done . The bulbs only last around 3 years or so. http://electrified.com/ this is the cheapest place you will find a new one.
Aug 02, 2009 | Sony Televison & Video
Electrical shock on audio video jack
there is a current if you dont use is sleeper or shoes and if your hand is weat of water. its normal. be sure that your TV is not fix eversince.
May 31, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv screen goes black for a few seconds
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot. if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
Mar 19, 2006 | Samsung TXD1972 19" TV
Televison & Video Logo
Top Televison & Video Experts
