Question about Delta Baby Gear
I have a Delta Marquis 4 in 1 convertible crib that I misplaced the hardware for and need to know where to look for the replacement screws and bolts that i need to change it into a toddler bed?
I am looking for all the screws and bolts for delta martine II
You might be able to substitute standard hardware but this will require some trial and error locating the correct parts in the correct sizes.
Dec 27, 2013 | Delta Martine Crib
I am missing all of the screws for the crib. We recently moved and lost all the screws for the crib.
Lowes carries most bolts and barrel nuts. Local small hardware stores may have longer bolts if needed. I sometimes use a bolt specialty business for unique bolts. Most cribs use either a metric set or SAE. If you are replacing the complete set choose whichever is easiest to find. If they bed has glued in threaded nuts go with the matching bolts style, metric or SAE.
Jan 15, 2013 | Delta Eclipse Dark Cherry Finish 4-in-1...
I need crib hardware for a LUV Delta 5 in 1 crib and bed model # 4-840
I need hardware as well. I called Delta Childrens Product Customer Service and they charge $35.00 for the hardware for my Luv 5 in 1 Crib (model 4822). I tried several hardware stores and none of the bolts I purchased fit. According to Delta, since the crib was made in Indonesia, the hardware has to come from that country.
Jan 20, 2010 | Delta Luv Delta - Baby Products 5-in-1...
Misplaced Hardware
not paying for a solution...sorry
Jan 06, 2010 | Delta Luv Delta - Baby Products 5-in-1...
I cant find the rails to convert my crib into a bed.
Delta Childern's Products has a very similar product called the Canton Crib (discounted)
I understand Simplicity is out of business, but I would try Delta Childern's Products Customer Service (AT YOUR OWN RISK) :
Monday-Friday 9am-5pm EST.
(800) 377-3777 extension 6221, or call
(212) 645-9033
Fax: (212) 645-9032
FYI: Many cribs may look similar, however their construction and hardware systems are different. Serious injury or death can occur if the incorrect hardware is used on a crib. Please ensure you actually have a Delta crib. Our cribs use a mattress board and not a metal frame. Our name Delta Enterprise or Delta Children’s Products can be found on the instruction sheet that is glued on the mattress board.
Aug 13, 2009 | Simplicity for Children 4-in-1 Convertible...
Missing screws and bolts for a brand new crib
go to
http://www.deltaenterprise.com/customer_service.asp
and their you can get new instructions and hardware
May 13, 2009 | Delta Enterprise Versailles 4970 Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Sep 23, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Baby Gear Logo
57 people viewed this question
Top Delta Baby Gear Experts
Paul Carew
William McDowell
Are you a Delta Baby Gear Expert? Answer questions, earn points and help others
