Question about Cozy Heating & Cooling
My cozy wall heater 10 years old. Turned on smells that cause headaches, but its not Carbon monizoide. One tech: reports nothing is wrong. 2nd, cleaning.3rd, chimmy chute needs cleaning. Any ideas?
    Top Expert:
  • Cozy Master
  • 80,417 Answers
Burning dust or pollen.
Posted on Dec 31, 2016
Fumes smell from gas heater
Open a window fast, carbon monoxide poisoning could cause death, and that has no smell ! are you getting headaches?? Contact manufacturer, they usually have a good warrenty. You must vent out the exhaust!!
Mar 04, 2015 | DeLonghi Heating & Cooling
How can I clean my suddenly stinky Cozy wall furnace?
It may well need a service if you have not had it done in 12 years this could well be a job for a gas fitter
Sep 13, 2012 | Rinnai Orbis Vented Heater 15,000 BTU Wall...
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
I have had problems with my Cozy gas wall furnace since it was new (its about 6 yrs old now) I won't stay on. It seems that every year I have to call out service people to get it to work. It always...
if the switch at the top of unit is tripping there is something wrong with the vent , the switch is set at 350 degrees it detects back draft do to a improper vent or blockage of vent, if the installer use the old vent system that is more than likley the problem, have the installer call Cozy tech line at 502-589-5380 so they can go over how the unit is installed.
Dec 07, 2010 | Cozy (W352E) Heater
New cozy wall heater makes alot of noise from heatexchanger poping and banging noises
if this is a w series unit measure from the top of grill to the floor, should have 68 3/8 on an inch if not the header plate which is installed in the wall was put in wrong have the installer correct this and the noise will go away. Cozy tech line is 502-589-5380 have the installer call so they can go over the install of the unit.
Dec 06, 2010 | Cozy (W352E) Heater
Pilot goes out
Remove the pilot gas assembly and clean the pilot jet. They can carbon up and partially obstruct the jet after a few years in service. If you can remove the jet altogether, clean it with a good quality automotive fuel injector cleaner or carburetor cleaner. Try not to use abrasives.
If equipped, check the pilot gas regulator - it may be on it's way out and need replacement.
Mar 27, 2009 | Cozy (W352E) Heater
Very loud wall heater (bang!!) heat up and cool down.
cozy heat exchangers do tend to make a lil more noise than avg. if its popping before the blower comes on its proubly the heat exchanger expanding. you would have to watch the exchanger while it was heating to see exactly what is causing the noise. but as a renter you should try reporting it to the landlord first and try to get a tech there before digging yourself
Mar 15, 2009 | Cozy (W352E) Heater
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Gas explosions coming out of Cozy wall heater
It could be one of two things. Either you have a weak gas valve or dirty burners. Either way you will need to get a technician out to check it in order to know for sure. Or if you have access to high air pressure you can try to clean your burners and see if that eleviates the problem. But you saod it has done it since new. I am leaning towards a weak/ or stuck diaphram in the gas valve.
Feb 16, 2009 | Cozy (W352E) Heater
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Heating & Cooling Logo
37 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
