Question about Vehicle Parts & Accessories
My alarm has same problems as well.
Alarm only can open or close the door and the light flash as well,but haven't got any sound at all
    Sergeant:
  • 273 Answers
You need to wire the alarm output to you car horn
Posted on Jul 21, 2009
Hazard lights flashing and alarm sounding. How do I stop these?
Every car brand and model has its procedure to stop the flashing light and alarm sounding.
But still the common procedure is Make sure boot and bonnet are closed properly.
It can also be a switch, but check your alarm by locking yourself inside the car, and then press the close button on the key 2 times repeatedly until the lock control on the door doesn't make anything. Then open the door by pushing the lever or open the hood . If the horn sounds and the lights blink your alarm is ok , if only the lights blink you should take it to dealer. You can stop the hazard lights and horn sound by pressing the unlock button on the key.
May 12, 2016 | Cars & Trucks
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why does my 1999 Lincoln Continental alarm system go off by itself and then shut off after 5 or 10 minutes?
this could be the door striker plastic has broken off this is the post sticking out of the frame when you close the door the lock closes around the striker to keep the door closed this striker could also have moved slightly from opening/closing the door thousands of times try this open your windows get out close all doors set the alarm wait a minute then try to lightly move the door/s in and out by grabbing the door at the rear part where the door locks to the frame where the striker is if it has any play in it the connection will break and this will make the alarm think the door has opened and the alarm will sound getting the door to close tighter will stop it from happening this is also true for the trunk if you press down on the trunk or your able to pull up on it a little the same thing will happen its loose and will trigger the alarm if this is not the problem I would then go to the door pin switches that turn the lights on/off when the door is opened/closed especially if the alarm was aftermarket installed but you can be sure the alarm thinks that something is opened and the door/trunk/hood are the only places that they are
Aug 21, 2014 | 1999 Lincoln Continental
Factory security system intermittently going off. Wondering if it is a bad sensor or switch. Does the door LED flash a code? 8 long flashes followed with normal short flashes.
CAR ALARM ISSUES
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
Nov 28, 2012 | 2003 Honda Pilot
2005 tahoe rear access door ajar alarm won't stop going off
I HAD THE SAME PROBLEM WITH MY REAR DOOR TAHOE 2001 ., I TOOK IT TO THE MACHANIC AND IT WAS SO SIMPLE A FUSER UNDER HOOK . $8.00 FUSER ., IF I WOULD IT KNOW . I WOULD IT DONE IT MYSELF.-- REPLACE FUSER WHERE IT SAID --HORN- ITS UNDER THE FRONT HOOK... I END IT UP PAYING $120.00 FOR THEM TWO HOURS WORK...THE LIGHTS AND THE ALARM WAS NON-STOPPING MAKING NOISE..... RIGHT..????
Sep 20, 2012 | 2005 Chevrolet Tahoe
Power lock remote control is not working to open and close the doors while burglar alarm light (armed) keeps on flashing. When any door is opened, sound keeps "on" to indicate problem. The...
Check under the hood. Often, there is a small switch that needs to be closed when the hood is shut. This switch sometimes comes loose and when the hood is closed the button is never pushed. Find the magic button and reattach it to it's mount so that the hood will press it when the hood is closed and that should solve the problem. This button works with the alarm system.
May 25, 2011 | 2001 Honda Accord
Alarm keeps sounding and blue light is flashing on dash board, if I close the door the alarm starts all over again. The alarm sounds very weak and weird. Car won't start,
This may sound silly but it worked for me. Try sticking the key in the drivers side door with the alarm going off and go through the motion of unlocking the door. Good luck.
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | 2004 Mitsubishi Galant
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
Jan 24, 2010 | 2002 Chrysler PT Cruiser
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
