Question about Samsung 997DF 19" CRT Monitor
Hp lcd monitor turns off after 4 or 5 hours
My hp 19 inch LCD monitor turns off after 4 or 5 hours. if it is off for a few hours, then you can turn it on again for a few hours. No physical evidence of blown cap. Could you help please.
the model number is: HSTND-2B01
thanks, Masoud
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 848 Answers
Hp lcd monitor turns off after 4 or 5 hours? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
490421200100R QLIF 041 HP 790421200A00R Power Supply Backlight Inverter
Posted on Dec 11, 2014
  • 37 Answers
Have you checked the soldering to see if theres any dry joints?
Posted on Jul 21, 2009
The display on the screen is jumping and does not hold still. Can this be fixed or is it time to replace the monitor?
A "previously-owned" 17-inch LCD screen probably will cost $30 to $50.
A brand-new 17-inch LCD screen is hard to find -- probably, nothing less than 19-inches is being sold, for $100 to $150.
An audio/video technician will charge $60 to $75 per hour to try to repair your LCD.
So, responsibly recycle (or "free-cycle") your old screen, and purchase a new 19-inch screen.
Jun 20, 2011 | Gateway FPD1760 17" LCD Monitor
HP L1906 19-inch color LCD Color Monitor ..suddenly stopped working (not even "no signal" message. What can I do please ? malcolm watson
First check all wires and connectors are tight and in their respective place.Then check supply to your cpu
OR
REMOVE YOUR POWER CORD AND HOLD THE ON BUTTON FOR LIKE 30second TO A MINUTE AND THEN CONNECT IT BACK AND TURN IT ON
Thank you for using fixya
Jan 06, 2011 | HP Hewlett Packard L1950g 19 inch LCD...
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
My Acer AL1917WAbd 19" LCD powers off ~2 second after power on.
The monitor this old I will not be surprise if you will find a lot of bad caps inside, see what goes wrong with LCD monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
If you have it repaired, you will more likely to be charged $80~90, I would put that money toward a new monitor, just do not expect them to last more than 3 years on the new monitors.
Apr 07, 2010 | Acer AL1917WABD 19 inch Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank...
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Jul 15, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Jun 21, 2008 | HP f1905 19" Flat Panel LCD Monitor
HP 19 IN. LCD MONITOR
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
Samsung 997DF 19" CRT Monitor Logo
226 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
