Question about Kitchen Ranges
How many inches from back of the stove to wall can't make out the diagram?
  • Kitchen Ranges Master
  • 5,659 Answers
15"
Posted on Dec 31, 2016
I have a drolet wood stove model # db03081 i need to know how many inches from the wall it has to be, i can't make out the diagram?
It is recommended that you have it 36 inches from an unprotected wall, if the wall is protected you can go down to 18".
Dec 31, 2016 | Home
How do I measure stove pipe?
The accepted technique for measuring stove pipe is by the inside diameter. Simply because the outside diameter of double and triple wall pipe are much larger by comparison to the inside diameter. There's no standard for outside measurement that would transfer in a logical manner.
Oct 14, 2014 | DuraVent DVL Dura-Vent DVL 8-Inch Vermont...
Installed today and there is a four inch gap between wall and back of range! How do I get to be flush with back wall? Counter depth 24 inches with 1/4 granite over hang.
Have your granite contractor cut a "stove strip" to fill the space.  Completely normal.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Jan 15, 2011 | KitchenAid KDSS907SSS Dual Fuel Range
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
We installed a Woodchief wc 100c woodstove and i
Hello, I have the same model. The plate on the back say's,install with min installation clearance's side and rear wall 18 inches fire door end 36 inches front 48 inches above 51 inches flue pipe 18 inches install on non combustible and non conducting base of 9/32 inch min thickness that extends 6 inches beyond the sides and 18 inches beyond fire door side. circulating fan type FF-100
Feb 23, 2010 | Heating & Cooling
F3 error code on stove has disabled the oven from opening. I need help in opening the oven and advice as to how to prevent another occurrence. The stove product number is 790.75761002 this however isn't...
The oven temperature sensor is bad. Open the oven look in the back wall of the oven on the top right or left side.There will be a 3 inch piece of metal sticking out,slightly smaller than a pencil thickness. Unplug the range. Remove the screws from the sensor and pull it out to disconnect the wiring plug. Install a new temp sensor.
Nov 10, 2009 | Kenmore Cooktops
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How to install ignitors on Viking Range
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range
Sep 07, 2009 | Viking VGIC485-6G Gas Kitchen Range
Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Jul 02, 2008 | Electrolux 30" Self-Cleaning Slide-In...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
