Question about Radio Communications
My funtab won't reset it's in talkback Japanese
How to get talkback turned off
Hi Michele
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
Feb 29, 2016 | Cell Phones
Ematic funtab pro will not boot
Do a factory reset. Ematic should have the instructions on their site
Jul 20, 2014 | Ematic FunTab Pro 8GB 7" Kids Tablet with...
Wat do i do when my funtab pro won't charge
Try using another charging cable, and/or plug into an alternate charging source.
May 30, 2014 | Ematic FunTab Pro 7" Multi-Touch Screen...
Ematic password reset
How do you unlock the screen on an ematic funtab if you forgot the password
Jan 04, 2014 | Ematic 7" Tablet Computer
My son's FunTab Pro will not charge.
One of two things could be happening. Either the battery has stopped working and you're going to need to buy a new one or the charger isn't working like it should so you might need a new charger.
Aug 27, 2013 | Ematic FunTab Pro with WiFi 7" Touchscreen...
HOW TO CHANGE LANGUAGE IN TOYOTA AXIO 2007 CD PLAYER TO ENGLISH?
This is a model which has only ever been designed for the Japanese domestic market.
You won't find an English manual, end of. It was never intended for English speaking markets so Toyota never went to the time and expense of producing the manual you ask for. Likewise any onboard graphics and operating assistance screens will not usually have alternative language choices.
It's also very unlikely that the video will ever work in anything other than the Japanese version of NTSC. It either has a universal decoder chip, and may offer (in Japanese) to reset the region coding for you, or it won't.
About the only thing you might get working (I presume you're in Europe) is the FM radio, but as Japan uses a different set of frequencies to Europe you'll need to fit a frequency expander to the radio (commonly available online or at car audio shops), but the frequencies shown on the display will remain incorrect.
One fix is to find a RHD 2007 Corolla at a scrapyard (not exactly common as the Corolla hasn't been supplied to Europe since before 2007) and to transplant the entire entertainment system across, but it will likely be of a far lower specification to your model. As you may have to obtain this from Australia/NZ it won't be cheap, and you won't know what you're getting until it arrives.
I'm sorry but I can't help for more.
Dec 02, 2010 | Toyota Car Audio & Video
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
