The turntable on my rockola 488 won't come on, does nothing
I have a rockola 444. The record wheel rotates continuously. but the selector arm never selects a record. What might be the problem? Thanks,
When you select a record the turntable motor is energized and the big wheel that holds the records should start turning...does that happen?
Nov 10, 2017 | The Audio Players & Recorders
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
How do I adjust the record speed on a rockola juke box
Check the turntable rubber grommets first, these when worn or perished will give a rumbling sound through the speakers but will also change the speed as they will allow the motor to drop down which will use the other size on the motor shaft
Nov 22, 2014 | Audio Players & Recorders
Jukebox manual
Many on eBay Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
Rockola jukebox 484 turn table does not turn,
Drive belt for the turntable is most likely broken. Need to replace it.
May 18, 2014 | Music
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Turntable won't play
Is it moving mechanically or nothing at all?
Sep 26, 2011 | Audio Players & Recorders
Rockola 464 jukebox. arm that holds needle will not move over to record
The turntable will need to be removed, the pladder should be taken off with the c clip to inspect the gears, I would not be surprised if the grease has gone hard and is interfering with the cycle. Flip the turntable over to check for any restrictions. If it is a grease issue the old must be removed before applying new. Please keep me posted on your progress and if I can be of further service don't hesitate to ask.
Jan 12, 2011 | Audio Players & Recorders
41 people viewed this question
