Question about Kitchen Appliances - Others
Toastmaster Oven TM-183TR - Brand New - Toaster setting is not working. Temp. is set at Min then I turn timer to just past 10 min then back dial to prefer toast setting Light-Med-Dark symbols
As per instructions. No matter what I tried the toaster setting would not heat up. The only way to get any heating elements warming up was to set the dial to Toast and the Temp. to 450 and the dial timer to 10 and back dial to toast preference setting symbol - doing that shuts off heating element when it gets to set temp., like 450 degrees. From my understanding the Toaster setting once turned on keeps the heating element on and red hot until the timer goes off, etc. All other settings work correctly!
Falling Down
  • 67 Answers
SOURCE: Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Posted on Nov 30, 2007
cactus bob
  • 267 Answers
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
cactus bob
  • 267 Answers
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
  • 328 Answers
SOURCE: The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Posted on Apr 05, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
Parts I need a new Broiler Rack (P/N 21432) for Toastmaster toaster oven, Model 337. Mine doesn't have the convection oven as it is an older model.
My manual has 1(800)947-3744 Mon-Fri 8:00 am to 5:30 pm CST I have purchased a broiler pan from calling them in the past; now my unit just died yesterday so need to find another.
Jul 01, 2014 | Toastmaster 337 Toaster Oven with...
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Manuel for TUV48E toastmaster oven
Finally found a link. I've been looking for months, all the links 'where not found'. Hope it works for you.
Feb 24, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
99 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
