I need to know if a mercury thermostat is bad will it allow the ac to come on but not the heater
    Top Expert:
  • Heating & Co... Master
  • 45,472 Answers
Need to know what thermostat you are referring to
the coolant thermostat has no connection to the ac system
if it is the ac thermostat the it maintains the cabin temperature by activating the ac compressor as required
if you are referring to climate control then that controls the heater flow to keep the ac temperature at a set temperature with the ac compressor operating all the time
so as an answer to you question , check the climate control module
Posted on Dec 31, 2016
After car is warmed up and thermostat has opened put the switch to heat it only blows cold air
There are several causes. I need to know what kind of car? milage? this iwll determine if they are manual controls, or electronic controls. Do you see any water/ antifreeze dripping from under the dash? If no...probably a control wire or vacuum line that should be opening a valve to allow hot water to run through the heater, that is not moving, remaining closed, NOT allowing hot water to run through the heater.
Oct 21, 2013 | 1996 Mercury Sable
2002 mercury sable ac not blowing but heater works any ideas?
Could be a blender door issue. What a blender door does is mix the cold air from the AC with the hot air from the heater core. If you put the switch ALL THE WAY to hot, the blender door (usually an actuator) pushes the door up and allows only air passing thru the heater core to enter the cabin. If you push all the way to cold, it only allows air from the AC. If you put halfway, it mixes/blends the air...
Aug 04, 2013 | Mercury Sable Cars & Trucks
2001 Mercury Sable 3.0 v6 heating problem had a flush done and changed the thermostat put new coolant in, replaced heater core, replaced blend door what else can it be
First make sure you dont have an air lock in your heater core and make sure you feel heat from the two heater hoses if you do fell heat your problem is under dash. If the hoses are not hot you have a blockage some where you may have a heater valve not operating it works by vaccum if u have AC look in the engine compartment or it maybe under the dash by heater core, I belive its in engine bay by Ac and heater boxes
Joe
Oct 08, 2012 | 2001 Mercury Sable
HEATER IN MERCURY SABLE ONLY BLOWS COLD AIR GOT THE AIR CONDICTION FIX NOW NO HEAT
Two things.........either it's a bad blender motor,or more likely,plugged heater core..Remove heater hose from near thermostat and heater hose from water pump,and flush from water pump side heater hose back thru the heater core and out the thermostat side heater hose with a pistol grip type water nozzle. don-ohio
Nov 05, 2011 | 1999 Mercury Cougar
Tried replacing old thermostat and now heater won't turn on
Make sure you get the t-stat back on the wall exactly as it was. It needs to be level for it to work properly. Then turn off the power to the furnace for a minute or so, then turn it back on. This will reset any faults that may have locked it out.
If this still doesnot work then you may have shorted the wires. Often on old systems the wire coverings are bad and if the bare wires touch any metal or even sometimes each other they can short out the transformer. If the transformer is dead them nothing will work. I'm afraid you may have done this inadvertantly.
Heatman101
Jan 25, 2010 | Heating & Cooling
Thermostat will not work on its own. If I take cover off and press the contact, it will engage heater. Once manual pressure is off the contact, the heater turns off. The mercury switch does not seem to...
Assuming that your talking about the heating unit inside the house, your thermostat is bad and should be replaced for at least 2 reasons. 1, mercury thermostats are no longer made because of health problems and so forth, and 2, mercury thermostats are far from being as accurate has a newer digital thermostat. You can buy digital thermostats fairly cheap at Home Depot, Lowes, Wal-Mart, etc. Installing them are simple, just follow the instructions on the product, its basically all color coded. The only tools you should need is a small standard or phillips screw driver, and a level. Hope this helps.
Dec 28, 2009 | Heating & Cooling
Greetings. i have a 96 mercury villager that neither the front or rear ac is getting cold. fan blows hot air... was told that it did not need freon and that the compressor checked good... any other ideas
yes it sounds to me like the thermostat control on the dash is malfuctioning. either that or heater control valve under the dash that converts the flow of air around or through the heater core could be stuck in heater mode. hope this helps. i dont know your financial situation but if it was me i would aquire one from a salvage yard in order to test because that part is quiet expensive from the dealer
May 18, 2009 | 1999 Mercury Villager
No heat in 97 mercury villager
your heater core may be getting blocked up, or the thermostat may be stuck open at times. you have a few options here, option 1 and 2 cost about the same, option 1: have the thermostat replaced just so you know its working properly, a 97 will most likely not have a telltale way of knowing if the thermostat is bad or going bad. option 2. have the cooling system flushed at a shop. this will try to clear out and debris in the cooling system that may be blocking passages or the heater core. option 3 is the most expensive. have the heater core replaced, the heater core is what provides heat to the hvac system in the dash. a few other things to check would be vacuum lines/actuator/temperature door on your hvac system.
Feb 16, 2009 | 1997 Mercury Villager
Thermostat thermometer broke - mercury?
Is this one of those heaters that has the thermostat down on the bottom by the gas valve, and not mounted on the wall somewhere?
Mar 12, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
