Question about Danze Plumbing
Removing handle from Danze faucet, model D457015
  • 14 Answers
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Posted on Jan 03, 2009
  • 2976 Answers
SOURCE: Handle of the danze faucet keeps shutting off. I can't tighten
Directly under the handle, you should find a ring that you can tighten, to eliminate slipping.
Posted on Feb 17, 2009
Biodgr8able
  • 18 Answers
SOURCE: how do you tighten or remove handle on a danze
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Posted on Jul 03, 2010
  • 760 Answers
SOURCE: Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Posted on Jul 12, 2010
mstrmstr
  • 60 Answers
SOURCE: I have Danze, single handle
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Posted on Dec 29, 2010
How do i remove handle from danze kitchen faucet?
Google Danze kitchen faucet diagrams and it shows the intricate parts of different faucets
May 03, 2014 | Danze Plumbing
Jul 12, 2010 | Danze Plumbing
There's no set screw or plate covering the set screw. Not sure if handle just snaps on or what Danze Parma faucet
You didn't indicate exatcly what model. Check this link, and follow the install instructions. It tells you how to secure each type (3 different methods) One is a screw in the side with a cover over the screw.
http://www.danze.com/tech_specs.asp?show=D500058BN then click on install notes
Jul 04, 2010 | Danze & Single Handle Tub And Shower...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
How do I remove the handle to check the Cartridge on a Danze D307456 Bannockburn Widespread Double Handle
You need to hold handle lever and unscrew the bottom escuteon plate you may need a small strap wrench it will turn counter clockwise. On some older models there was a set screw on the handle which you would use an allen wrench
Nov 13, 2009 | Danze D307456 Bannockburn Widespread...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Water leaking from tap when turned off
Hope this helps.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
105 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
