I recently moved an now my rockola 488 won't power up
High rpms low power
Was the fuel drained and fresh added? Gasoline has a self like and then it starts to turn into a gunky mess that doesn't burn well.
Jan 01, 2018 | Cars & Trucks
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
What causes a Rockola jukebox not to index?
I might be wrong about this but check inside for a switch marked Scan/off/play inside at the front of the mech. It should be in play position. Also check any circuit breakers and reset them on the upper back of the machine (inside). They look like the clicky end of a ball point pen.
After that I am stuck.
May 16, 2014 | Neonetics Rockola Jukebox Neon Clock
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Been given a grade 5 Rockola 160 433, need a copy of the service manual
Contact the folks at www.victoryglass.com and tell them the make and model of your jukebox. They will have the manual set for around $50. Also, they bought out the entire Rockola factory parts inventory. So if by chance you needed Rockola parts, they would have it.
Aug 05, 2013 | Wurlitzer Rock-ola Jukebox
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
Rockola jukebox
This is in the wrong section
May 17, 2013 | Kitchen Appliances - Others
35 people viewed this question
 Grubhead
Grubhead
