Question about Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine
My krups xp5240 is not producing espresso shot but instead producing coffee and it wont stop dripping till i turn to stop knob.please help!
    Top Expert:
  • Krups Master
  • 76,848 Answers
Has it been cleaned with white vinegar?
Posted on Dec 31, 2016
SOURCE: Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Posted on Jan 27, 2009
  • 279 Answers
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
Posted on Sep 18, 2009
  • 39 Answers
SOURCE: espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Posted on Dec 29, 2009
  • 39 Answers
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
  • 39 Answers
SOURCE: my Krups combo espresso/ coffee maker xp2070 will
Do you have power to the control module? Can you set the time or is the display completely dead? Mine was completely dead and I replaced the power module and the display/control module.
How to disassemble espresso machine.My gasket leaks
i think its not a gasket problem may be broken pipe or broken thermal block if you have a broken pipe it is due to not cleaning the filters you get an over pressure on the internal pipes and bingo water come out be wear of electric
Sep 13, 2015 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
Function switch is broken off just where it enters the body of the machine.
A parts sheet shows the switch as part of the front fascia. Unable to give you the part number, it depends on which market (country) it is for.
Sep 08, 2013 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
Krups XP5240 very loud pop sound while steaming
Take it back to the retailer, tell them about the noise and the water leak. It's under guarantee so you should not be looking for any self help solutions, it's faulty.
Mar 12, 2017 | Krups Coffee Makers & Espresso Machines
Krups orchestro art889 water is coming down into drip tray and coffee grout holder instead of the coffee dispenser
Most likely the main O-rings have to be replaced. There is an excellent step-by-step instruction available on http://www.kaffeemaschinendoctor.de/Downloads:_:30.html under Jura, Aeg, Krups - It's in German, but Google can translate it. This repair is not for the faint at heart, but it can be done. The O-Rings can be found in any decent hardware store.
Mar 26, 2010 | Krups Orchestro 889 Espresso Machine
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water goes directly to drip tray instead of to the brewing head.
Have the same issue with mine. Descaled it all and wouldn't even brew with no coffee OR filter in the housing, so I took it in to get it checked out. Turns out it's the solenoid valve that needs replacing. ~$60 part plus $90 labor, so I've decided to try and find that part and DIY, if I can. I'll let you know how that turns out!
Aug 04, 2009 | Krups XP4030 Espresso Machine
Why doesn't my Krups espresso maker produce crema when I brew espresso? Very little is produced and gets blasted away by the time it's don't brewing.
Crema is the goldish brown top that goes onto the top of the coffee once it is dispersed from the espresso tap and flows naturally as part of the coffee when coffee is made. Im not sure what you mean "blasted."
Perhaps you should flush through the machine with cold water a couple of times beforehand and also consider a descaling kit - check your manual or Krups if there is one for this model.
Crema isn't produced by any machine though.
Jul 25, 2009 | Krups XP 4050 Espresso Machine
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Xp5240 Perfect Tamp Xp5240 Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
