Question about Electrical Supplies
Insinkerator slowly leaking from the bottom - Electrical Supplies
    Top Expert:
  • 75,817 Answers
The shaft seal has failed, I don't think they service this, so a new deposal is needed.
Posted on Dec 30, 2016
Testimonial: "THANKS"
  • yadayada
    yadayada Dec 31, 2016
    Mine starting leaking about 3 months ago, then it really let go and water went all over. This never used to happen have had the brand for 40 years in lots of homes, cheap parts made in china.
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Insinkerator leaking from bottom
Any leak from bottom part of disposal means replacement.
Copy following link for specific troubleshoot, and replacement steps with tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Nov 05, 2012 | Badger 5 Insinkerator 76037h 1/2 Hp Feed...
Insinkerator leaks water from the bottom. this is when water runs through. no difference if the unit is running or not
There is no repair, just replace the unit. Once they start leaking, that is fatal. you could not repair for less than replacement of the unit.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water does not flow, it flows very slowly. even the motor does not work.
You need to use a plumbing snake to clean the drain from the output of the InSinkErator, just as you would clean a sink drain. On the bottom of the InSinkErator there will be a small button that will actually be a circuit breaker. This needs to be re-set by pushing it in. I would also get an appropriate size Allen wrench and insert it into the bottom of the ISE at the center. This will allow you to turn the ISE by hand and perhaps break up any debris that might be in the unit. DO ALL THIS WORK WITH THE UNIT UNPLUGGED!!!
Aug 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leak in the bottom of insinkerator 1-81 near reset button there are two little flange looking things one is leaking rapidly when water is on
depending on the age it sounds like you may have to replace the unit,, insinkerator is the best on the market so when they leak it;s time for a new one ,, if not to old and under there warranty they will send some one to ifx it just call the 1-800 number on the unit
Jun 13, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Electrical Supplies Logo
354 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
