Question about Honeywell Water Heaters
Where are the gas pressure tabs located in the honeywell vr 8304k 4822 gas valve ? This is the manufacturer's reference number. The pressure tabs are to read/adjust the gas inlet and outlet pressure
  • yadayada
    yadayada Dec 31, 2016
    vr 8304k 4822?? What is that?
  • Julio Posada
    Julio Posada Dec 31, 2016
    Top Expert:
  • Honeywell Master
  • 45,659 Answers
Being gas and you are not a qualified gas fitter, the sensible thing to do is to get a gas fitter in to adjust /fix the unit
of course the unsafe thing to do is to try and do it yourself
Posted on Dec 31, 2016
Hi, i have a water heater (Rheem XG50T...) w/ a wifi module. Today, the temp / pressure relief valve drained a little bit and now my water heater does not work as the error A102 does not get clear eve
Error A102 ?
Where does the error code show on your model?
The XG50T appears to have honeywell gas control valve that flashes error code with series of blinks, and not LCD readout.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If the release of water got electronics wet, then the electronic parts likely will not function.
Release of water from TP valve means temperature of water inside tank exceeded the temperature-pressure rating of TP valve.
This is a safety feature.
Water from TP can indicate thermostat failure, or other less serious issues.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Your water heater appears to have 9 year warranty.
Serial number located on label on side of tank will have numbers- 1st and 2nd digits are week of manufacture, 3rd and 4th digits are year of manufacture,
Call Rheem since they do not post service manuals.
Other companies post service manuals and are much easier for DIYers.
Gene
Water Heater Timers Save Money
Dec 06, 2014 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gas valve faultdetected
Copy following link to troubleshoot by type of gas control valve, and read how to replace gas control:
There are basically two types of Honeywell gas control valves.
One for atmospheric-vented water heater, and one for power-vented
For both types of controls: 8 flash + 3 flash error: replace gas control valve.
Water heater does not need to be drained to replace this gas control.
Apr 01, 2013 | Honeywell Water Heaters
Why is gas boiler burning black sut
This is dangerous condition. Call service technician immediately, and they might put the unit out of commission until repairs are made.
Locate manufacturer's website, and call manufacturer to get name of local technician qualified to work on unit, and this will get the unit back into working service quicker.
Soot means burner is not burning all the fuel, and venting is slowed.
Possibility unburned gas is entering flueway, and could cause explosion.
Clean burner parts, check vent draft, check gas pressure.
Catch unit up on required yearly maintenance.
Jan 05, 2013 | Honeywell VR8200C6008
Gas boiler makes a lot of black sut
What should the gas pressure be on pilot?
Copy following link to troubleshoot by type of gas control valve:
Bradford White posts service manuals: Both before and after introduction of ICON (Honeywell) gas control valve
http://www.bradfordwhite.com/documentation/residential/gas.asp
Don't forget to clean air intake locate under combustion parts, using instructions in service manual. Or compressed air. Ample air supply will ensure that combustion chamber does not overheat because of slowed venting of hot combustion by-product that will trip the FV system.
And remove heat trap inserts if water pressure has problem or water heater is humming or whistling
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 28, 2012 | Bradford White MI40T6FSX 40 gallon LP gas...
Rheem power vent 2 flashes red led twice
Copy following link to identify gas control valve and download error code information by type of gas control, and possible service manual.
If you have Honeywell gas control, then 2 flashes with three second interval can mean pressure switch has failed. And or related issues.
Scroll up on same page to find pressure switch heading among the troubleshoot links.
Or use Ctrl+F find feature on browser, and word search page for 'pressure'
Same page also has Rheem parts list 2010 so you can locate exact part number using model number that shows on label on side of tank.
Rheem does not post service manuals, but other companies do, and they can apply to Rheem (except for the FV system, which varies by manufacturer)
Best that you save product manual when possible because it will have important information including, parts warranty, error codes and parts list. Plus routine recommended maintenance that can prevent outages and error codes
Sep 06, 2012 | Rheem Water Heaters
How do l replace the electronic gas control valve on a whirlpool hot water heater tank?
Whirlpool is made by American water heater.
Gas valve is made by Honeywell.
Whirlpool electronic control is version of Honeywell 'Icon' gas valve: There are several versions of this gas valve.
http://waterheatertimer.org/pdf/Bradford-White-service-manual.pdf
Start page 24 shows: Testing, disassembly and replacement of typical Honeywell gas valve.
Whirlpool phone number 1-877-817-6750
Whirlpool manuals:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Aug 10, 2011 | Whirlpool Water Heaters
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
Water Heaters Logo
54 people viewed this question
Top Honeywell Water Heaters Experts
Paul Carew
Lawrence Oravetz
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
