How do I change the thermostat on a EdenPure Gen3 heater Model A3705?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My edenpure heater turns on
If you have continuity through the bulbs then the next most likely thing is the thermostat...
If you check here you will see that they sell the t-stats so I would check that out...
Check for continuity through the t-stat and if there is none then you know what to try..
heatman101
Posted on Dec 04, 2010
Why won’t my edenpure heater throw heat even though I changed all the heat elements
It could be a fuse. They are small look kinda like a metal diode. Unplug heater, disconnect one side of power wire and do a continuity check on the heat strip circuit. You can also plug it in and do a voltage check on the two wires connected to the heat strip. Do this to see if you are getting voltage to the strips. Some heaters have safety switches that disconnect power when the heater falls over. It's a free swinging switch that might not have reset.
Dec 23, 2017 | Heating & Cooling
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
Edenpure thermostat
near the intake filter inside the back of your unit
Dec 09, 2013 | Heating & Cooling
Edenpure troubleshooting
try them in the working slot to see if there ok if not get new other wise controller is shot 3 yr warranty by edenpure
Dec 04, 2013 | Heating & Cooling
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
Edenpure xl1000 parts
Replacement bulbs can be gotten from edenpure parts or check EBay for a supplier. Some will ship them no charge. To change them. Remove rear cover, then the cover on the rear of the heater box by 2 screws on the bottom and 1 at the top inside of a "U" Channel. Then lift the rear box cover up off the hanger hooks then back and out. The bulbs will be right in front of you in the 3 holes.
Jan 25, 2013 | EDENPURE USA 1000 Black Portable Heater -...
Eden pure starts blowing hot air and then turns cold
I recently fixed this issue for a family member on this exact model, the same issue, it would heat fine for 15 minutes and then cold blowing air would follow afterwards non stop, and when we powered down the unit and restarted it, it did the same exact thing. ( What worked for me ) was ordering a new " Thermostat " which is a white rectangle looking plastic thing with 2 blue wires coming out of it, you can find You-Tube video's showing you how to remove the Eden-pure gen3 cover housing easily, my total cost of this do it yourself repair was just under $20 as of 10/10/14 your cost could vary depending on different factors.
1st...unplug the unit....duh ! lol
Once the housing is removed, look at the top of the unit and locate the 2 blue wires coming out near the front, remove the 2 top screws holding in the thermostat, gently pull out the old thermostat but don't disconnect any blue wires yet, put the new thermostat in facing the exact same way as the old one, re-tighten the 2 screws, next follow one blue wire ( One is longer than the other ) to its location on the block, determine if its the shorter or longer wire, disconnect just 1 wire with a Phillips screw driver, and replace it with the like sized blue wire from the new thermostat, tighten but not over tight ! next do the same for the next blue wire on block.
After thermostat is secure and wiring is secure, put the cover and panels back together......and plug it in and test it again....... Hope this works for you as it did for me.
Good Luck !
Oct 12, 2012 | EDENPURE MINT A3705 Infrared Remote...
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
Heating & Cooling Logo
205 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
