Question about Electrolux Dryers
EF1 error code electrolux dryer - Electrolux Dryers
    Top Expert:
  • Electrolux Master
  • 77,932 Answers
Here is a link to the service manual for the dryer.
Posted on Dec 30, 2016
EF 2 code frigidaire dryer
Only Codes listed that are close on Tech Sheet are EF1, EF3 and EF8. Many Other codes but not in that format. There is an EF2 Code for Frigidaire washers for oversudsing.
Nov 18, 2015 | Frigidaire Dryers
E75 default code on Electrolux gallery series dryer
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
May 19, 2015 | Electrolux Dryers
Electrolux dryer error code e62
Good Afternoon Friend,
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 11, 2014 | Electrolux EIED55H Dryer
Error code 08
Good Morning Friend,
I understand that you are receiving a 08 error code on your Electrolux dryer, model# T4530. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
May 29, 2014 | Electrolux Dryers
Electrolux error 93
Good Afternoon Carolyn, this is Z. I am happy to assist you!
I see that you are receiving an error code E93 on your Electrolux dryer. Typically this indicates that the main control board has possibly gone bad or is not communicating correctly. I would suggest resetting power to your dryer for roughly ten minutes. If the error code still displays, at this point, I strongly recommend connecting with a local appliance tech that has the expertise to distinguish which part is the culprit. I hope this information proves useful.
Apr 05, 2014 | Electrolux Dryers
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Oct 12, 2012 | Electrolux Dryers
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Jan 02, 2011 | Electrolux Dryers
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
Aug 14, 2010 | Electrolux Dryers
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Sep 25, 2009 | Electrolux EIED55H Dryer
Dryers Logo
314 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
