Question about Food Processors
Kitchen Aid food processor. Dropped a spoon into it while running. Stopped & removed spoon, it continued to process food, but blade seems to be stuck on shaft, so I can't remove bowl or blade.
    Top Expert:
  • Food Processors Master
  • 77,939 Answers
You damaged the blade or bent the shaft, not sure how you could get it off.
Posted on Dec 30, 2016
The bowl of my 14 c food processor will not release from the base - the cutting blade is in place
You will probably need to force the blade off the shaft somehow. If you over work them the blade can partly turn and lock onto the plastic shaft sleeve. A Kitchen Aid Authorised repairer will have figured out a way to remove it by now because it's been happening for years. Expect to replace the blade or the sleeve or both, once it's happened it's easier to happen a second time unless you replace parts.
Nov 23, 2017 | Food Processors
How do I get a dough blade for kitchenAid food processor Model 4KFP 600 WH
Kitchen Aid list them, it's on this page called blade, dough
Feb 24, 2015 | KitchenAid Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
Blade spins and hits side of bowl
Get in touch with Kitchen Aid, that should not be happening.
Feb 19, 2014 | KitchenAid Food Processors
Kitchen aid food processors 's chopping blade gets stuck . Very hard to take it out
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Aug 23, 2013 | Magimix 5100 Cuisine Systeme Food...
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Sep 17, 2009 | KitchenAid Food Processors
Kitchen Aid Little Ultra Power, 4 yrs old, suddenly stopped.
Jul 13, 2009 | KitchenAid KFP450 Ultra Power 7 Cups Food...
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Replace processing glass jar for bravetti quad blade food process
type bravetti in search bar. There might be something you can use in your quest.
Apr 08, 2009 | Bravetti Quad Blade Food Processor
Food Processors Logo
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
