I placed a plate over the holes in the lid of the dehydrator, waring pro,it shut off, I waited until it cooled down, it will not come back on, Is there a reset button, or do I need to trash it ?
    Top Expert:
  • Office Equip... Master
  • 49,171 Answers
Quite likely by blocking the vents you burnt it up no reset that I know of .
Posted on Dec 30, 2016
Testimonial: "Thanks, I was short on counter space and that was the only space available ! :0("
  • 1 more comment
  • ray gallant Dec 30, 2016
    quite a bummer we have to use the top of washer and dryer when that happens here at home
  • Pat tasker
    Pat tasker Dec 30, 2016
    I live full time I. An RV, so space is limited; I was dehydrating sweet potatoes for "my girls", so unless I decide to spend the extra money, I'll have to dry them in the oven ! I like to make each potato into four slices, so it takes quite a bit of time to dry them out !
  • ray gallant Dec 31, 2016
    AH sounds good to me
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
I have a LEM 778 10 try stainless steel food dehydrator the machine when running runs okay until the end when product is almost dry then the fan motor turns off and still hear the motor running. Heat and...
Most of these stainless dehydrators have a cheap timer which uses plastic gears turned by an electric motor to operate the machine. After being on for a while the whole timer will heat up and the gears unside will begin deflecting and failing. When this happens the only thing to do is wait for it to cool down and see if it works again. Eventually it will fail completely and the machine will jus tstart shutting down halfway through cooking.
It is possible to bypass the timer and use an outlet timer, but each model of machine is wired slightly differently. You would have to consult a knowledgeable electrician.
There are newer models on the market which have digital timers. These work muuuuch better, but the fa
Jan 10, 2014 | LEM Products lem Stainless Steel...
A week ago our dehydrator worked fine and today it is blowing cold air as it used to blow hot air.. help
Hi, Check if it has fuse and /or replace. Use another plug in the room. If all is OK heater coil maybe burned out. Replace.
Jun 12, 2011 | Conair Waring Pro DHR20 Food Dehydrator
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    Lost the instructions for a nordic ware microwave corn popper
    1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
    2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
    3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
    4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
    5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
    Jun 27, 2010 | Kitchen Appliances - Others
    What is the plastic solid removable plate with the hole in the center for inside the dehydrator
    I finally found out this is a Ronco dehydrator. The plastic plates have nothing to do with dehydrating but are for making fruit leather. We had bought the dehydrator used and it only had one plate. We had a difficult time figuring out what it's use was since it came without instructions. Ronco didn't put their name on the dehydrator either.
    Oct 10, 2009 | Nesco Gardenmaster Digital Food Dehydrator
    Bunn coffee drips slow
    I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
    1) Unplug the NHB
    2) Remove accessories like the pot and basket
    3) Bring NHB over to the sink
    4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
    5) Place the top cover and flow stopper aside.
    6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
    7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
    8) Return the NHB to the upright position in the sink.
    9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
    10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
    11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
    12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
    13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
    14) Tip the unit as in step 7 to drain the tank water out.
    15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
    16) Repeat steps 13 and 14 once.
    17) Repeat steps 11 through 14 three times.
    18) Clean the pour reservoir cover, swing lid and flow stopper.
    19) Put the flow stopper back in place.
    20) Attach the top cover.
    21) Clean the exterior of the NHB.
    22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
    23) Turn the boil and warmer plate switches on.
    24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
    25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
    26) Allow water to drain from brew spout until it stops draining.
    27) Empty pot.
    28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
    29) Clean brew spout diffuser and replace back in the brew hat.
    30) Clean the pot, pot lid and brew basket.
    31) Wait ten minutes for the water in the tank to boil.
    32) Brew your coffee as you normally would.
    The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
    Apr 05, 2008 | Bunn NHB Coffee Maker
    Waring Pro WC1000: Pour over 12 cup coffee maker
    Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
    Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
    32 people viewed this question
