Question about GE Refrigerators
Ge gss25tgp at first the freezer dtop working now its both the fridge and the freezer.idk if its quick cheap fix or better to just buy a replacement than having it fixed.
    Top Expert:
  • GE Master
  • 51,191 Answers
Depends on the AGE of it there is no CHEAP fix
oddly enough
Posted on Dec 30, 2016
I have a GE gss25tgp, I was hearing noises earlier now i just went back to the fridge and now the water dispenser and ice dispenser aren't working would that be a control board issue?
The dispenser control board is fed from the main control board located in the back. The main control is usually the root of most problems .Order from repair clinic if it does'nt work they will take it back.
Dec 05, 2016 | GE GSS25TGPWW / GSS25TGPCC Side by Side...
How can I fix my fridge?
think twice. You replace this, but it still is a 14 year old fridge. Next week something else can go down. The newer ones use less power to cool the same amount.
Buy a new one, you have warranty, and in its lifetime it will save you money on the electricity bills.
Jul 17, 2014 | GE Profile PSW26P Stainless Steel Side by...
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
I have the GE GDS20SBSS only 6 years old. I paid about 1200$, and I have been advised to buy a new refrigerator. The freezer works but the refrigerator won't keep cold temp. There is frost in the...
Oh my God that's crazy. You can change this yourself part number WR55X10942
Bi Coastal Appliance Parts 1-800-673-1262 around $150.00 + shipping
Sep 14, 2011 | GE GDS20SBS
We have a ge profile refrigerator and there is water leaking on the left side under the freezer. The inside of the ice tray has tan colored gunk on the ice and the bottom shelf of the freezer has a 1/2 in...
manually derfrost fridge/freezer,clean with bicarb only...... dry as best you can.(important) clean drain hose fill freezer from top with any spare space filled with foam in plastic bag(s)looks awful but works a treat (cheap too)invest in a freezer thermometer minus 20C IS BEST.....
Feb 07, 2010 | GE Profile 20.7 cu. ft. CustomStyle...
Freezer side working reefer side warm ge side by
There is a vent that gets clogged. The easiest way to fix it is to let it thaw for 24 hours (open-48 would be better). This is much ceaper that calling for a tech. Cold air from the freeezer is what keeps the fridge side cold.
Jun 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Ge monogram refer/freezer not freezing or cooling
could be 3 things 1,the thermostat could to faulty ,2,the system might need gas pull the fridge out and check the motor at the back if its red hot gas would seem to be the problem 3, also with the fridge pulled out if the motor is stoppping and starting the motor windings are gone ,replace the fridge , no quick fix with this problem sorry
Mar 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
