Question about Electrical Supplies
Have onan 7.5 HDKAJ. will not start. what is code 19?
    Top Expert:
  • Electrical S... Master
  • 75,797 Answers
A code 19 on this genset is Governor Actuator Fault. But this code will not be set until after the engine has tried to start. The Governor controls the throttle.
Posted on Dec 30, 2016
Why onan 7500 HDKAJ rv generator will not turn over.
If the start battery is definitely good then why is the starter not getting energized? Ignition switch? Low oil switch, on/off switch? Safety switch?
There is something that you are overlooking. Bet that if you take a wire and hook up one end to the + terminal on battery and the other end to the plus wire on the starter it will crank!!!!!!!!
Sep 21, 2015 | Electrical Supplies
Rv onan rv runs but now makes a rackett when running was real quiet
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
Jan 12, 2014 | Onan Electrical Supplies
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Microwave ovens need to be connected to a separate, dedicated line.
Nov 28, 2013 | Grilling
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
By pbarker987 on Jun 02, 2010 " " I have an onan microquiet 4000 KY. It will not start, fault code on red light indicates (35) control card failure. Before I take it to authorized onan repair is their...
Because it wont start does not indicate a control board problem It will start but it will shut down within a few seconds if it was. enail me and i will try to help you with the problem jbogilvie@hotmail.com
Jun 23, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
