Question about Panasonic Lumix DMC-FZ20 Digital Camera
Unable to get pics from camera to computer?
Tried everything unable to offload pics
  • 2,985 Answers
Re: unable to get pics from camera to computer?
Tell us more about the everything!
You habe connected to USB cable from camera to Computer - Yes?
Switched on the Camera and set to 'Upload - Yes?
If you have installed the software disk- uninstall it and let the Computer sort it- which it can.
Are you using an external card reader- which is preferable to uploading from camera by the way.
Just tell me more.
Posted on Nov 20, 2007
0 characters
3 Points
What type USB cable needed to offload pics
You don't need a USB cable.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( ).
Jun 15, 2013 | Kodak EasyShare CX7300 Digital Camera
Unable to transfer pics on computer
once you connect your camera with PC computer,, it will take some seconds to create an drive letter ,, with you camera name.. go to explorere and open and see, you have pictures in it..
Sep 29, 2009 | Fuji FinePix A210 Zoom Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Rebel XT offloading pics
I use Picasa for me photo handling and sometimes it seems to take forever for the computer to read the camera. Try giving it some extra time to hook-up. WHat do you use to download your pics to?
Sep 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I need software to download so I can get pictures off my camera
use a memory card reader to bypass camera and offload pics-about 15-20.00 and works great-no power cords or software needed
Aug 17, 2008 | Digital Concepts Digital Cameras
New memory card.
See if there is a copy feature in menus where you can internally copy from internal memory to card-kodaks and some other manufs offer this feature-i would offload internal pics w/usb to computer and then just start using new card-get a memory card reader also and you can put from comp back to memory card w/reader-no need normally to format new memory card-just don't format internal or you will lose pics
Jun 27, 2008 | Samsung Digimax S630 Digital Camera
Not able to transfer pics to computer (fuji finepix f470)
What computer and operating system have you? Meanwhile try this Remove any third party image software. for example if you have the Fuji software in take it out
Sep 27, 2007 | Fuji FinePix F470 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
73 people viewed this question
Top Panasonic Digital Cameras Experts
Level 1 Expert
Are you a Panasonic Digital Camera Expert? Answer questions, earn points and help others
