Question about Air Tools & Compressors
I need a diagram of a pressure cut off switch from a emglo airmate compressure over under tanks
  • yadayada
    yadayada Dec 31, 2016
    Sorry we don't have that.
  • 9 Answers
SOURCE: I would like to know the type of oil and
any small compressor oil will do like dewalt,quincy....or 30 sae oil
Posted on Jun 05, 2009
  • 12 Answers
SOURCE: emglo airmate AM78HC4V; when trying to start
I had the same problem. Replace the motor capacitor. small white cilinder part with two wire plugs conected to it. This will have a single bolt holding it to the frame casing, you will find it under the black plastic shroud that covers the motor. Take it into any electrical or compressor shop and they will check it for you. costs about $35.00.
Posted on Jul 07, 2009
  • 98 Answers
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Posted on Jul 21, 2009
brewerstool
  • 141 Answers
SOURCE: Have emglo airmate when I turn it on the overload
It could be a couple of things. To me it sounds like you have a short in the motor or damage to the cylinder and piston. You need special equipment in order to test the armature and field for a short. There may also be damage to the brushes and brush holder. There could also be a problem with the cylinder and piston. The bearing could be bad causing a hard start for the motor. I think it could be the combination of the two problems listed above. You may want to check the pump first and if that is not the problem it is an electrical short in your motor in which case you should buy a new compressor. It will cost more to fix if the motor is damage than to buy a new one. "BER" Beyond Economical Repair.
Posted on Oct 01, 2009
mrhappyface
  • 205 Answers
SOURCE: Have an emglo that will not start. Replaced the
may have tripped the overload look for a reset button allot of them have the number 15 on the tip of the button try pushing it in and see if it starts or if it is buzzing when you try and turn it on it most likely is the capacitor
Posted on Oct 07, 2010
Testimonial: "Did try the reset switch to no avail - no buzz"
Compressor will only build up to 40lbs tank pressure
Hi
Seems a little strange being a factory reconn.that this problem has arissed, if it is under some sought of warranty after reconn. the take back and ask then to sought out.
If its out of service warranty then it could/maybe pressure switch setting.
John
Jul 29, 2011 | Dewalt d55151 factory reconditioned emglo...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Emglo airmate AM78HC4V; when trying to start compressor the motor will only hum
Jun 08, 2009 | Dewalt d55151 factory reconditioned emglo...
DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Compressor will not shut off
The switch is bad, replace it, this should solve the problem.
Nov 17, 2008 | Dewalt d55151 factory reconditioned emglo...
Air Tools & Compressors Logo
88 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
