Question about Photography
I need to replace 3 leg locks on my TGT-BK58T tripod. Can I get the locks only? I will replace myself if the parts are available.
  • Photography Master
  • 5,077 Answers
It appears to be made by a company called Targus - contact their spares and service department.
Posted on Dec 30, 2016
    Top Expert:
  • 45,653 Answers
Camera shops sell tripods for cameras and telescopes
go there and ask if parts are available for your unit
I need the non-slip rubber feet for the tgt bk58t
take a sample along to a rubber retailer as they have a selection of rubbers that may do the job
Oct 04, 2016 | Targus Tgt Bk58t 58 3 Way Panhead Bubble...
Can I get parts for a damaged tripod
Contact the importer or manufacturer, telling them the exact make and model number, plus a full description of the problem, with photos if possible. Alternatively, take it to a nearby camera shop or repair facility.
Jun 23, 2016 | Giottos Mtl9351b Mh5011 3-way Head Tripod...
Is there a "lock" position on on the 3 leg spread of this tripod?
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
Aug 25, 2014 | Velbon Aef-3 Tripod
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
The lower leg would not lock and comes off.
The grey part might be a shim that fits up into the leg lock in order for it to fit more securely. Ambico is no longer in business, and parts are not available so you might have to replace the tripod if you can't fix it yourself. You find tripods here: www.itripod.com
Feb 22, 2013 | Ambico Photography
Are all targus tripods quick releases the same?
No, but you can find some here at www.tripodquickrelease.com.
Sep 04, 2012 | Targus Tgt Bk58t 58 3 Way Panhead Bubble...
Hello! I have own for like 15 years a Bogen tripod. Lately I have to tighten the legs screws very hard to keep them in place. How can I solve this? thanks, Luis
Depending upon the model of the tripod, the legs where ithe locks are may be bent, mis-shapen and need to either be replaced or rotated. It all depends upon the model since there are many different styles and some may not be repairable eother due to age or parts availability. Some of the digi series just are expensive enough to repair.
Apr 04, 2010 | Photography
One leg on my tripod does not lock. It moves no matter if the lock is engaged or not. What can I do? Thank you
leg locking mechanism of the leg is failed,so replace the broken part to get it locked.
Mar 16, 2010 | Giottos (IY-332) Tripod
Lost quick release plate on Targus TGT-66TR 66'' Tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod
Jun 07, 2009 | Photography
Is it possible to buy a replacement leg for a GB1140?
I would contact the factory and see if they have replacement part available. Try their website and ask. Most large retail manufactures have parts avaiable.
http://giottos.com/
Jul 06, 2008 | Giottos GB1140 Tripod
Photography Logo
76 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
