Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Screen goes blank
Hi, I have a problem with my samsung screen. Each time I switch on my CPU along with the monitor, the screen comes on and then goes blank. The windows boot and my caps lock light works.
After about 10-15 mins i then turn off and on the screen, it becomes normal. Each time I have to wait this period. Could anyone help me to solve this problem. Thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
It's an LCD so the problem is most likely the back-light inverter board. Take a flashlight and shine it directly into the screen from the front. Can you see the image on the screen now? If the image is there but you can't see it without the flashlight than the inverter board needs to be replaced. This is a VERY common problem. Good Luck and let me know what happens, His Dudeness
Posted on Jan 21, 2015
Its simple bro , Your CPU is not reading RAM,so just Remove and Re Insert the Ram to in DIMM Slot and then Switch on Computer it will work fine.
Posted on Jul 21, 2009
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Samsung SyncMaster 223BW monitor screen goes blank
You should get three years warranty, if you can locate your receipt and contact them direct they will sort it for you :)
Good luck
Jul 25, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 245B
Call Samsung. The unit sounds faulty.
Dec 14, 2007 | Samsung SyncMaster 245BW Monitor
Monitor works for about 30 mins then goes blank with a messahe reading 'Not Optimum'
Hi Rick I have the same problem. Have you found a solution yet? I had the power supply tested, that is not the problem. It seems to go off when it gets hot. If I point a fan at it, it seems to last longer before blacking out. Pete
Feb 23, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
331 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
