Question about Exercise & Fitness
Charged my fit fitbit shows 5 lights but then when I put in wrist band no lights and won't sync.
SOURCE: how do i adjust my watch band??
You have to bend the watch band at the location of the arrows all the way back until you bend the metal outward. Have a flat head screw driver with you. Remove the link, and re-bend the metal back with the screw driver. That should work.
Posted on Jan 24, 2009
SOURCE: Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Posted on Mar 11, 2009
SOURCE: wrist band adjustment on a fossil watch
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
Posted on Apr 30, 2009
SOURCE: I want to size my wife's Peugeot ceramic watch
I just got finish resizing the White Ceramic Peugeot watch I bought my wife. It's very simple to do
Posted on May 20, 2011
  • 47 Answers
SOURCE: watch band
You can buy anywhere because branded watches will not get any problem in branded watches. Do you know here get the best offer in your watches, Discounted Watches247
Posted on Mar 30, 2015
How to set time on fitbit
There are some specific things you can do depending ion what Fitbit you have, but without knowing that, here is some general advice. Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order. Check if your device has the correct time before moving on to the next step.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
5. Try resetting your Fitbit (specific instructions depend on which one you have).
Oct 20, 2017 | Exercise & Fitness
What do i do to sync my fitbit? I have it pluged in to the usb.
  1. How Do I Sync My Fitbit -‎
  1. Search How Do I Sync My Fitbit. Visit & Look Up Quick Results Now!
    Search & Find Now · Quick & Easy Answers · Find Relevant Information · Learn More
Search Results My tracker won't sync, what do I do?
  1. Make sure your tracker's battery is charged. ...
  2. Close the Fitbit app and then open it again. ...
  3. Turn off Bluetooth, then on again, and then open the Fitbit app. ...
  4. Try turning your iPhone off and on again. ...
  5. Uninstall and re-install the Fitbit app. ...
  6. Try resetting your tracker.
Fitbit won't sync to your iPhone? Here's the fix! ' iMore Feedback
About this result People also ask What is all day Sync on Fitbit?
How do you change the time on a Fitbit?
Why is my Fitbit not working?
How do I connect my Fitbit to my computer?
Help article: Why won't my Fitbit device sync? 5 days ago - If your Fitbit device still won't sync, try these steps: Force quit and then reopen the Fitbit app. Go to Settings > Bluetooth and turn Bluetooth off and back on. Open the Fitbit app. ‎iPhone or iPad · ‎Android Phone · ‎Windows 10 Phone or Tablet
Fitbit Help - Syncing Why won't my Fitbit device sync? Try these troubleshooting steps if your device is not syncing. How do Fitbit devices sync their data? Learn how your device ... ‎Why won't my Fitbit device sync? · ‎How do Fitbit devices sync ... · ‎Fitbit app for iOS
Fitbit Help - Troubleshooting Why won't my Fitbit device sync? Try these troubleshooting steps if your device is not syncing. How do I restart my Fitbit device? Troubleshoot a problematic ...
Help article: How do Fitbit devices sync their data? Jump to How do I manually sync my tracker or watch? - To manually sync your device, with your device nearby, open the Fitbit app and find the picture of your device on the Fitbit app dashboard. Touch the picture of your Fitbit device at the top of the screen and pull down (on Windows 10 devices, find the picture at the bottom and pull up).
Solved: How do I force sync? - Fitbit Community 19 posts
Can't force sync: I can't seem to find the fitbit connect page, nor the icon to right click on to force the sync. My fitbit won't sync since yesterday at 8:35 am.
what do do to sync my fitbit Google Search
Sep 30, 2017 | Exercise & Fitness
How do I latch my fitbit
Can't get my flex strap fastened. - Fitbit Community
  1. Cached
  2. Similar
Mar 3, 2014 - I have trouble fastening my Flex, too. Not only is it difficult to line up the holes with the latch, but I somehow can't press hard enough to click the ...
Clasping and switching your Alta wristband - Fitbit Community
  1. Cached
03-14-2016 13:19 - last edited on 04-25-2016 16:54 by ErickFitbit Moderator. Options. Mark as ... How do I clasp my Alta wristband more easily? Before putting ...
Solved: can't fasten band to wrist - Fitbit Community
  1. Cached
  2. Similar
Since it wasn't on my wrist, I could see how to align the band to get the clasp to go through both pieces of ... HelenaFitbit ...... I cannot get my fit and to latch at all.
How can I latch the band easily? - Fitbit Community
  1. Cached
Jan 19, 2014 - Latch is very difficult. Accepted Solution. 0 Votes. Reply · All forum topics · Previous Topic · Next Topic. 1 REPLY. 01-19-2014 20:16. Options.
Anne Corey - I can't attach my Flex to my wrist. Can not... ' Facebook
  1. Cached
  2. Similar
I can't attach my Flex to my wrist. Can not get the little teeth to go ... To see more from Fitbit on Facebook, log in or create an account. Sign UpLog In. Not Now. How do latch my fitbit Google Search
Dec 28, 2016 | Exercise & Fitness
How do I set the time on my fit bit?
  • Log in to your dashboard and click the gear icon in the top right corner.
  • Click Settings.
  • Scroll to the bottom of the Personal Info page and modify your timezone.
  • After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
  • Nov 02, 2016 | Cars & Trucks
    I need replacement for My fitbit L . Suddenly cannot be charged & non show in the viewer . Mike Agaiby My address 3050 wentworth way Tarpon Springs FL.34688
    It your Fitbit is still under warranty, contact the manufacturer.
    If not, try reviewing this website on problems on charging your Fitbit.
    Why isn my battery charging
    They review dirty contacts, faulty USB cable or charger, alignment of the cable connection and a faulty Fitbit.
    If your looking to buy a new Fitbit you could try Ebay
    14 899results for fitbit
    or Amazon
    Amazon com fitbit
    I really don't like the charging types, my wife and I both use the Garmin Vivofit wristbands. The battery is good for a year or so and requires a single small watch battery to be changed. Has an Android app that it syncs (Bluetooth, wireless within 30 ft.) with and makes tracking much easier. This is what it looks like:
    Amazon com Garmin vvofit Fitness Band Black GARMIN Cell Phones Accessories
    BTW Mike, never, never, never give out your name and address over the internet. "Thar be dragons here, friend ....."
    Nov 02, 2016 | Exercise & Fitness
    My fitbit is not syncing
    My Fitbit suddenly stopped synching with my iPad and iPhone. It is fully charged and the lights show on my unit.
    Sep 28, 2016 | Fitbit Flex Wireless Activity & Sleep...
    How do I sync my fitbit ulta
    Bring your charged fitbit near to the plugged-in dongle or base station. You may need to press your fitbit button or tap it to wake it up. Then, Click the Fitbit Connect icon. Finally, Click Open Main Menu, and then click Sync Now. You may be asked to sign in, after which your fitbit should sync with your account.
    If these steps do not work then please review the link below for additional trouble shooting tips.
    Why isn my Ultra tracker syncing to my computer
    Aug 03, 2016 | Exercise & Fitness
    I don't like the band on my charge. Will the band on a hr fit a Fitbit charge. The one on the charge keeps coming off my arm.
    Fitbit Store: Buy Surge, Charge HR, Charge, Flex, One, Zip ...
    FitbitBuy Fitbit devices and accessories at our official online store for free shipping on $50+, 45-day money back guarantee and 1 ... Interchangeable Bands ... Fitbit Charge HR™. HEART RATE + FITNESS WRISTBAND .... United States (change).
    Fitbit Charge HR Review: This Is The One You Want
    GizmodoFeb 4, 2015 - The Charge HR, on the other hand, has a standard watch strap with a closure that ... Well, most fitness trackers out there are really just glorifiedpedometers. ... With the HRM, I took my pulse (or had a friend take it) and then check the display. ... Fitbit claims the Charge HR will last "up to five days" on a fully ...
    Fitbit Charge HR Fitness Wireless Activity Wristband Review
    Jan 19, 2016 | Exercise & Fitness
    My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
    How to fix broken Fitbit - sync Fitbit with phone app - PC ...
    May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
    Fitbit Flex review - The disappointment we've all been ...
    May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
    Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
    Exercise & Fitness Logo
    35 people viewed this question
    Top Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
