Question about Yamaha Audio Players & Recorders
Where can I find a fuse for my Yamaha subwoofer?
    Top Expert:
  • Yamaha Master
  • 77,499 Answers
Any electronics store can supply the fuse, just bring it with you.
Posted on Dec 30, 2016
Yamaha ns-sw300 no sound no power
The first thing id look at is the fuse you have to open this up to look at this.Look inside the fuse and see if theres a rod like thing going from end to end.If there isnt thats your problem or if you see a fog kinda thing in there or if the walls of the fuse is black like a burn would represent.Most likely this is your problem but it could be more further of a problem than i anticipate.
Mar 15, 2013 | Mackie SWA1801 Subwoofer
My YST-SW015 stopped working out of the blue. It turns on just does not produce any sound. I feel like it might be a fuse issue ... but on the other hand i have very little knowledge about the technical...
You have to remove back panel in order to find fuse. Check it, then check resistors - one of them can be black colored - it's burnt. In my case problem was in STK 404-070 power amplifier. Replaced and sub works again.
Jun 08, 2011 | Yamaha YST-SW015 Subwoofer
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
No power i have checked the fuse in the plug and the lead is fine. Yamaha Ysp1000 sound system
There well my be some internal fuse. If the unit is self powered then the amp may have a problem.
Dec 11, 2009 | Yamaha YSP-1000 Main / Stereo Speaker
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Subwoofer will not turn on
Does anybody have a solution to this problem?
Jan 05, 2009 | Yamaha YST-SW45 Subwoofer
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
43 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
