Question about GE Dryers
DCVH680EJMV GE electric dryer. Selection knob only operates in "cotton" mode, no other options work or light up.
  • GE Master
  • 8,220 Answers
Check the knob it might be cracked around the stem.
Posted on Jan 04, 2017
  • 4 more comments
  • Dennis S
    Dennis S Jan 04, 2017
    Sorry, 1st thing I checked
  • Dan Webster
    Dan Webster Jan 04, 2017
    control thermostat is working but stuck clothes overheating wrinkled
  • Dan Webster
    replace control on blower housing is what i would do especially if it is a bias one with 4 wires 2 small and 2 large
  • Dennis S
    From initial start - selection knob only lights up "cotton setting" when turned to other functions, no lights and no start.
  • Dan Webster
    Dan Webster Jan 05, 2017
    thermister same as control thermostat. Change it The electronic brain does not know what the inside temp is
  • Dan Webster
    thermistor will be on blower where a old school thermostat would be
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
The clothes aren't drying as in they re still WET!! I put it in timed mode for 40 mins. And the heat level's adjusted for cotton.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]
Aug 08, 2011 | GE Dryers
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
My timer is not working. the turner is turning to loose. it does not click while turning. the start button does not begin.
Common problem with the GE dryers is the start button will crack and will not catch the stem. Try changing the start knob over with the heat selection knob and see if you can start then.
Feb 01, 2010 | GE Dryers
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
120 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
