Question about Boating
40 HP 2 cycle outboard. Tilt works, but engine does not turn over. Yamaha outboard should mention.
  • Boating Master
  • 19,111 Answers
So either the battery needs charging, the starter button / key are faulty, or the starter/solenoid is faulty. You need a test meter.
Posted on Dec 30, 2016
Testimonial: "battery is a year old, and I just fully charged it, so I think it has to do with either a inline fuse, or the solenoid. Boat is in Florida, and sits for 9 months. Just re-attached all the wiring, and maybe something is not connected properly. Tilt works fine."
  • Andrew Taylor
    Andrew Taylor Dec 30, 2016
    There is no inline fuse to the starter circuit as it takes too many amps. Check wiring, the starter wire is the thick Red one, then with a meter at the solenoid, and then at the starter. Sitting 9 months is not good. Mine sits 5, I miss the Lake, Ontario that is :>)
How much oil to be add to 25 ltrs petrol for 40hp Yamaha outboard??
50:1
1 liter of oil to 50 liters of petrol
1/2 liter of oil to 25 liters of petrol
Oct 03, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Will low fluid level cause power trim/ tilt go not hold position
Low fluid level will cause it to fail to actuate and not go up or down, can also let it not hold position as well. Filling to proper leevel with specified lubricant is recommended. If you allow the level to go too low, the pump will pull air and could burn out.
Sep 21, 2014 | Yamaha Tilt Trim Motor, 40-90 HP Outboards...
Outboard problems
Broken connection in the wiring harness(loose)
Jul 28, 2014 | Yamaha Tilt Trim Motor, 40-50 HP Outboard
I cannot start the motor or raise the tilt and trim. Have power to the starter solenoid. have powere to the starter
check the control box , use multi metre and check the trim button and ignition key ! check main harness socket on the engine for corrosion or breaks in the wires !
Apr 11, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Problem with yamaha 50 hp
Check the oil level to see if it's over filled... Use Google for other options.
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
Boating Logo
57 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
