Question about Hitachi L40C205 40" LCD TV 1920x1080, 60 Hz, HDTV
How to adjust the convergence, it's not listed in the menu.
    Top Expert:
  • Hitachi Master
  • 43,010 Answers
There isn't any such adjustment
Posted on Dec 31, 2016
Resetting eeprom
These sets including this one have 3 hidden menus---OPTION menu which allows a hard reset of everything except the convergence, Adjustment menu--be careful in there, and Convergence menu which adjusts better than customer one and saves better.
Each is accessed with a four number code using the Mitsubishi remote.
I have a list of most of the codes available.
Nov 07, 2012 | Mitsubishi Televison & Video
How do i reset my mitsubishi television model#ws-55511
First a reset may not help unless I know what your problem is.
If model listed (WS-55511) IS CORRECT: set has 3 hidden menus:
Option Menu (hard reset of all settings to factory)
Technical Menu (Adjustments for various things)
Convergence Menu for adjusting convergence.
THESE ARE NOT ACCESSED FROM CUSTOMER MENU. Each requires Mitsubishi remote and a 4 digit code .......
So, What is your issue with the set?
I have the codes but it depends on model number and what problem with set is, reset is in Option menu but will not cure all problems.
SD TECH
Nov 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen had a red an blue blur
lilretard93,
Try using the convergence adjustment; listed at the bottom under the picture settings in the menu. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure about $300.00 USD for your model.
-Chris
Aug 23, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Lost bulb convergence and all input except for digital
With TV turn off Press and hold Vol- and CH- at same time ,wait untill TV turns on then you should be in service menu adjust convergence,BUT if when TV is on and you Go to menu then setup and you do not see convergence listed in menu ,you have a blowed fuse FL231
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to adjust the convergence on my RCA R52wh77 tv there is no convergence button on system anywhere. TV is only 2.5 yr old and I really don't want to pay $300 to have them come and adjust tube when I can...
you have to go into the menu,sometimes convergence is listed in the video section.
the chasis number is ITC222.
some had manual convergence then you have to adjust red onto green,blue onto green DO NOT MOVE GREEN
if it has autoconvergence activate it.do not do anything until its done.
Sep 18, 2009 | RCA R52WH73 Projection Television
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
Convergence off. Repairman said IC and one resistor bad. I am certified for soldering boards. I just finished replacing these parts he listed on my reciept. He also said adjust.. How do I adjust the...
Get the remote and go to Menu and go to Initial Set-up and click on the convergence button. You will then be able to line up the pluses in the middle of each color. When they are lined up you are ready to go.
Sep 24, 2006 | JVC AV-56WP30 56" Rear Projection...
Hitachi L40C205 40" LCD TV 1920x1080, 60 Hz, HDTV Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
