Question about Lochinvar Pool & Spa
My lochinvar xlp pool heater model # kbn501 shut off and the screen reads setpoint met maintenance required what do i do and what is the problem
  • 11 Answers
SOURCE: pool heater Maintenance
It is vitally important that your water chemistry be maintained. Pool water that is acidic or alkaline will attack your heater's internal components in a relatively short time. A monthly (minimum) analysis by a reputable pool store will help you maintain proper water balance and extend the life of everything in your pool, be it pumps and equipment, ladders and handrails, marsite, paint or vinyl liner.
Posted on Jan 03, 2009
SOURCE: Pentair pool heater reads HI
thermister needs to be replaced. follow small yellow wires off control board to front header and thats where the thermister goes
Posted on Jun 22, 2009
  • 990 Answers
SOURCE: I have a Raypak model 153 pool heater. The heater
For some reason your heater is not recognising the flame when it goes on. The biggest reason for this will be small spider webs in the burner orfaces. These are on the main gas manifold where it connects to the burners. You can get a small wire and bend it to go in these orfaces but the first time you do this it will probally be easer to pull the tray and remove the orfaces from the gas line. Good luck, I hope this helps.
Posted on Nov 28, 2009
  • 9 Answers
SOURCE: Blown Heater blower motor
you will have to replace the brain unit its shorted out
Posted on Feb 01, 2010
  • 990 Answers
SOURCE: I'm thinking of buying a Lochinvar Energyrite
My boss once asked me if I could work on a Lochinvar. I told him I could pronounce it.
Chevy is a car and so is Mercedes Benz. Lochinvar is the same kind of German engineering. Quality product. Tough to find people qualified to work on one and pricey at that. Great heaters though. As far as the model I have only worked on the big ones.(commercial) I have found if you work on them one time they stay fixed.
Posted on Dec 01, 2010
What do I try when my lochinvar spa heater says lockout ignition failure
turn off then try again means that it tried 3 times check gas if ok see if ignitor is lighting
Feb 05, 2015 | Lochinvar ENERGYRITE 250K BTU NATURAL GAS...
Hello, I have a Lochinvar ern 252, it was working great last season and was winterized properly... I just open the pool and now it is reading lockout ignition failure.... I can smell gas when it goes into...
two things, is it a spark igniter or hot surface?
if spark igniter is working then the pilot tube or fuel path to the igniter is plugged, a lot of times small spiders or insects will winter over in these tubes, build a small web or cocoon that restricts gas flow to the igniter. OR hot surface igniter not hot enough and will not lite the gas. can be tested with an amp probe or just replaced .
May 25, 2014 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
Boiler won't reset error message is air pressure sw
Check the induced draft pressure switch's tubing that connects it to the induced drat assembly, the barbed port that the tubing connects to gets clogged requiring reaming annually or this will happen, if this does not work replace the switch, make sure to clear the port.
Dec 07, 2013 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
I have a Lochinvar pool heater that on the dispaly is showing Air Pressure Switch Open. I looked at the manual and it talks about air flow from the supply vent and exhaust vent. Than it says about...
Hi and welcome to FixYa, I am Kelly.
Try this before taking anything apart to far:
The pressure switch is located in the front header, behind the
upper side jacket panel, above the water connections. When
required, the pressure switch can be reset with the following
procedure:
1. Clean filter and skimmer.
2. Start filter pump.
3. Set digital thermostat to highest setting.
4. Turn the adjustment knob on the pressure switch clockwise
until the combustion air fan in the front control panel turns
off. Fan will not turn off if system pressure exceeds 5 PSI.
5. Slowly turn the adjustment knob counter-clockwise until the
combustion air fan turns on. Turn knob an additional ΒΌ turn
counter-clockwise.
6. Turn filter pump off and on several times. The heater should
shut down immediately when the pump stops.
7. If the heater does not shut down immediately as the filter
pump stops, repeat steps 4, 5 and 6 until proper operation
is achieved.
8. Reset thermostat to desired temperature setting.
If after doing all of the above you still have the problem.... you can remove the switch and check for debris in the water passages. If you find debris remove it, reinstall the switch and repeat steps above.
- Still have the problem... Replace the switch.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
Lochinvar model ER152. The control module keeps bouncing from "Pool mode prepurge" to "pool mode ignition". I hear a click like it's trying to star up then it repeats itself. The spark...
This sounds like a problem with the gas supply. It could have a clogged orifice causing the problem. Make sure the gas is turned on and the gas valve in the heater is turned on. Pull the gas orifices and make sure there are no spider webs in them.
Nov 01, 2017 | Lochinvar ENERGYRITE 150K BTU NATURAL GAS...
I'm thinking of buying a Lochinvar Energyrite 402000 BTU Natural Gas Heater for my pool and spa. Does anyone have experience with this manufacturer or model? I'd like to hear the Good, the Bad and the...
Nov 30, 2010 | Lochinvar Energyrite 402000 BTU Natural...
Lochinvar The boiler is purging, ignitor is getting hot, but
This could be something as simple as a gas valve turned off. First check all the gas valves, (one inside the heater, one outside and one at the source.) Also if this is LP gas make sure that you have enough gas. It takes at least 30% in the tank before the heater will fire. In many places their may be an earthquake valve. If this fails it will shut the gas down to the heater. Their are many reasons the heater won't fire and the fellow who told you to change the board probally works for Lochinvar. You might want to have a repairman look at the heater first before you spend that money. Good luck.
Feb 16, 2010 | Lochinvar ENERGYRITE 250K BTU NATURAL GAS...
Circulating pump shutdown piolet lite shut off on boiler
It sounds like you have a circulation problem. The bleed off valve should only open when you have a presure problem (nonexistent on the open system of a pool) or when you have a over herating problem witch will shut down your pilot also. Check your heater by-pass valve. (A valve in an "H" on the inlet and outlet of the heater) This should be 80-90% closed to force water through the heater. If not this the standered; check the baskets, clean the filter and make suree there is enough water to keep the pump primed. I hope this helps, if not send more info on what is going on.Good luck.
Nov 05, 2009 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Pool & Spa Logo
48 people viewed this question
Top Lochinvar Pool & Spa Experts
Paul Carew
rogerpaul3
Level 1 Expert
David Spradling
David Spradling
Are you a Lochinvar Pool and Spa Expert? Answer questions, earn points and help others
