How do I wire my pratfalls 130 - Washing Machines
How do I wire my Piaf 130 sowing machine
it is 'sewing' unless you are going to use it to broadcast seeds, and it might be a Pfaff? :)
Ho do you mean 'wire it'? There is a wire that goes from the wall to the foot pedal, and a wire that goes from the foot pedal to the rear or the machine or to the motor itself. I have contacts for all the foot pedals.
Piaf 130 Google Search
Dec 30, 2016 | Sewing Machines
Wl80t65c 130 fault
Rotor position sensor Error .. Sensor is not send correct signal to control.
1)Sensor could be bad
2) wire from sensor broken
3) control board bad.
Jun 13, 2013 | Washing Machines
Error code 130
Rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Oct 22, 2012 | Fisher and Paykel Washing Machines
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
Fisher Paykel GWL11 fault code 130
its really important the R.P.S you replaced is correctly fitted so double check it,also the connecting block if corroded in anyway will cause the faulty its easy to see the bluey color of corrosion, i have struck faulty new sensors beforebut not all thst common if you are really sure all that is 100% then it can only be the wiring loom
Feb 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
I had to order a new 24 VAC relay for my 130 XP now I can't remember where all the wire go can you help?
CR1 It appear wires 7 and 18 go to the contactor armature. And the contacts interupt/contact wires 10 and 11.
CR2 it appears wires 5 and 14 connect to coil armature and the contacts interrupt wires 25 and 3.
Page 28
http://www.millerwelds.com/om/o1316f_mil.pdf
Jan 25, 2012 | Miller Welding Tools
I need a code for my remote
Panasonic Universal Remote Code for TV/VCR
Admiral 200
Aiwa 180
Akai 014, 015, 016, 142
Audio Dynamic 011, 240
Bell & Howell 005. 013
Broksonic 081, 136
Canon 125, 135
Citizen 006
Craig 005, 006, 141
Curtis Mathes 130, 300
Daewoo 001, 130, 250
DBX 010, 011, 240
Dimensia 300
Emerson 003, 080, 081, 135, 136, 243, 250
Fisher 005, 007, 008, 009
Funai 081, 136
GE 130, 170, 300
Goldstar 006
Hitachi 000, 125, 300
Instant Replay 125, 130
Jensen 240
JVC 010, 011, 190, 240
Kenwood 006, 010, 011, 240
LXI 000, 005, 006, 007, 008, 009
Magnavox 125, 130, 150
Marantz 010, 011, 240
Marta 006
Memorex 009, 130
MGA 230, 241, 242, 243, 330, 340
Minolta 000, 300
Mitsubishi 230, 241, 242, 243, 330, 340
Multitech 004, 330
NEC 010, 011, 190, 240
Olympic 125, 130
Optimus 006, 100, 140, 200
Orion 081, 136
Panasonic 100, 101, 125, 130
J.C. Penney 000, 005, 010, 011, 130, 240, 300
Pentax 000, 011, 300
Philco 081, 125, 130, 136, 150
Philips 125, 130, 150
Pioneer 125
Proscan 000, 001, 002, 125, 130, 150, 300,
310
Quasar 100, 101, 125, 130
Radio Shack 005, 009, 130, 170, 210, 241
RCA 000, 001, 002, 125, 130, 150, 170,
300, 310
Realistic 005, 009, 130, 210, 241
Samsung 002, 004, 220
Sansui 081, 136, 240, 520
Sanyo 005, 009
Scott 001, 002, 004, 009, 081,136, 230,
241, 330, 340
Sears 000, 005, 006, 007,008
Shintom 050
Sharp 200, 210
Signature 2000 200
Sony 140, 141, 142
Sylvania 125, 130, 150
Tashiro 006
Tatung 010, 011, 240
Teac 010, 011, 240
Technics 100, 101, 125, 130
Teknika 130
Toshiba 001, 310
Vector Research 011
Mont. Wards 006, 009, 200, 210, 290
Yamaha 005, 010, 011, 240
Zenith 290
Codes for Cable Box
Puser 544
RCA 170
Realistic 544
Regal 130, 350, 720, 730, 731, 900
Regency 560
Rembrandt 005, 544, 702
Samsung 005
Scientific Atlanta 122, 130, 131
Slmark 001, 005
Sprucer 005, 121
Stargate 005, 544
Teleview 001, 005
Texscan 810
Tocom 700, 701
Toshiba 004
Unika 531, 544
Universal 522, 544
Videoway 006
Viewstar 541, 542
Zenith 000, 280
Zenith / Drake
Satellite
ABC 530
Archer 531, 544
Cableview 005, 544
Citizen 005, 522
Curtis 130, 131
Diamond 530, 531, 544
Eagle 541
Eastern 560
GC Brand 005, 544
Gemini 522
General
Instrument/
Jerrold
122, 360, 520, 521, 522, 530, 531,
532, 533
Hamlin 130, 350, 720, 730, 731, 900
Hitachi 003, 530
Macom 003, 004, 005
Memorex 542
Movietime 005, 544
Oak 002, 702, 710
Panasonic 120, 121, 132
Philips 006, 007, 540, 541, 542
Pioneer 001, 260
Pulsar 005, 544
Codes for Laser Disc
Panasonic 200, 201, 235, 380
Pioneer 370
Sony 240, 241, 242, 243
Codes for DVD
Denon 100
Ferguson 110
Nordmende 110
Mitsubishi 150
Panasonic 100
Pioneer 120
RCA/Proscan 110
Saba 110
Sony 140
Thomson 110
Toshiba 130
Yamaha 100
Zenith 151
Codes for Cassette Deck
Aiwa 760, 761, 762
Denon 800
Fisher 603
Jensen 657
JVC 780, 781
Kenwood 600, 650
Marantz 751
Nakamichi 631
Onkyo 651, 652, 656
Panasonic 700, 730Philips 751
Pioneer 630
RCA 763, 770, 771
Sansui 631, 653
Sharp 800
Sony 740
Teac 653, 654, 658
Technics 700, 730
Yamaha 601, 602
Mar 06, 2011 | Panasonic Televison & Video
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
93 jeep wrangler 6 cyl. my temp gauge never shows full temp. only goes to about 130 degrees. I have a 195 oem thermostat but still gauge does not climb above 130,...bad gauge, wiring???
Assuming the t-stat is good, I'd look at the wiring next. Make sure the connector is clipped onto the water temp sensor/back of the gauge and that the wiring is not chaffed, etc. If that all looks good, replace the coolant temp sensor...they're $20 or so. If it still does it, the gauge is bad.
Apr 15, 2009 | Jeep Wrangler Cars & Trucks
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
