Question about Retail Supplies
My casio dl 1308 cashregister will not print.
I have changed ink cartridge it still will not print.
  • 749 Answers
SOURCE: Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Posted on Oct 28, 2007
  • 291 Answers
SOURCE: Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Posted on Apr 03, 2009
  • 2306 Answers
SOURCE: black won't print. Changed all ink cartridges,
It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
Posted on Jul 01, 2009
  • 1335 Answers
SOURCE: I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Posted on Oct 07, 2009
Testimonial: "I have a Lexmark X1180 printer. Excellent feedback and also very prompt! Thankyou"
  • 201 Answers
SOURCE: changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Posted on Oct 26, 2009
We have a Casio 130cr cash register and when we print the reset report, the amounts is not clearly readable. The 1 000 prints over the 100 and is not alligned propperly. How do I fix it?
They are cheap printers and not designed to last. It is common when they are worn or dirty. Clean the rubber drum and any ink or muck from the printer. Check the ink roller. Make sure it is fresh and rolling freely. If it doesn't improve, you just replace the printer as a unit. See a dealer for this. -----------------------------------------------------
If anyone needs more information, the Casio 130CR manual is here:
130CR user manual:
130CR service (repair) manual:
Aug 19, 2011 | Casio Parts Cash Register PC Desktop
Searching for a cash drawer compatible with a Casio TE-4500F it currently has a DL-3616
Basically any DL drawer with the same connection on it as the one you have. Sometimes the register may not sit perfectly on top - some drawers have holes to secure the feet of the register, but it should be able to open the drawer. -----------------------------------------------------------------------------
If anyone needs more information, the Casio TE-4500f manual is here:
Aug 16, 2011 | Casio Parts Cash Register PC Desktop
Replaced ink roller, 2nd receipt copy has no imprint. changed tape to newer roll, no difference. is there an adjustment for strike force on the casio PCR 272?
This machine can not use carbon type double copy paper. Only the old metal drum impact printers could use it. As far as I know, there are no longer any registers manufactured in the world that can use it now because the memory in all but the most basic models will permit two receipts to be printed from memory. You have the most basic model, so yours can not do double receipts. If you move up to a thermal printing machine, it should be possible.
If anyone needs a manual for a Casio PCR-272 cash register, try here:
Feb 09, 2011 | Casio Parts Cash Register PC Desktop
How to print the stores name in casio 130cr
This model is too basic to print text. it has a tiny drum printer so it can print numbers. Move up to one of the SE-S models to print text.
If anyone needs a Casio 130CR manual,
Operation and programming manual:
Service manual:
Oct 15, 2010 | Casio Parts Cash Register PC Desktop
We have an error showing - E94 and we cannot get any keys to ring or open the cash drawer. How can I fix this?
This sounds like a Casio. E94 refers to printer failure. Check to make sure their is nothing jamming the printer. Remove the paper/ ink cartridge etc, then turn off at wall. Turn key to REG. Turn on at wall
Casio cash register operating / user / programming manuals here:
Aug 04, 2010 | Casio Parts Cash Register PC Desktop
How to change a ir-40 ribbon on the PCR- T275 Cash register.
The PCR-T275 is a thermal printing register. It does not use an ink ribbon. You simply use 57mm thermal paper and make sure the shiny side is to the front. If you are having printing problems, let me know and I'll try to help. ---------------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-T275 manual, there's one here:
Apr 09, 2010 | Casio Parts Cash Register PC Desktop
I have magicolor 2300 DL.I just replaced Cyan
make sure your cartridge is not stuck and pushed in all the way in printer. If it gets struck it will dump ink out and waste it.
Aug 19, 2009 | Konica Minolta magicolor 2300DL Laser...
Casio 325cx printing problem
Please remove the cartridge and install it again..If its not woking then replace the cartridge.
May 21, 2009 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
46 people viewed this question
Top Retail Supplies Experts
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
