Question about Bissell Vacuums
Brushes are not spinning on Bissell steam cleaner
    Top Expert:
  • Bissell Master
  • 76,848 Answers
Check the brush belt for wear or being broken and missing.
Posted on Dec 31, 2016
When handle is in lock postion the brushes are spinning and when yu move the handle down the brushes stop spinning ( HELP ) Thank you Morgan Yochem
seems like theres a bad contact there must be the switch when you have it up its working and when you bring it down looses contact
Feb 16, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Where is the red lint filter that is described in your troubleshooting for lost suction??
It is on the bottom, close to the spinning brushes. It is the red plastic pushed down into the input of the vacum turbine tunnel that utilizes the vacum from the water collection tank to spin the brushes. Make sure that the stem of the master brush is not broken off, after pulling up and out to remove the brush holding container.
Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell 9200 proheat X2 wont **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
r
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes not rotating
heatman101
45wtw
Jun 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
There is no solution going to the carpet
belt needs replacement, or pump pulley melted/sheered off.
May 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Brushes aren't turning on Bissell Proheat 2X and it is almost new.
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Apr 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes don't spin and not picking up water
Depending on your model, the belts may be worn or broken. You can get replacements here:
ProHeat Replacement Belts
Nov 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat perfect pass
Manuals for all Bissell machines can be downloaded from www.bissell.com.
Mar 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
