Question about Grundig Audio Players & Recorders
In need of a replacement aerial for my Grundig S450DLX Short Wave Radio.
Grundig gu37fhd1080
Hi Bill
It sounds like a fault with its main system control memory IC. Please contact any service technician, to confirm it. In most cases, this component might need replacement. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
Where can i download the Grundig S450DLX Field radio Service Manual?..Thanks.
You say Service manual and its is possible you are looking for the schematics of the radio or how to repair it. I admit I have no idea where you can get it. However, here is the link to the user's manual.
Feb 11, 2013 | Grundig Audio Players & Recorders
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
How do set default AM & FM stations? Every time I turn on the radio I have select the station I want.
When you turn on the radio or select a wave band the display shows the last frequency you tuned in. That gives you 3 frequencies: One for the AM nd, one for the FM band (and maybe 3 for SW.
That does not look like much but there is nothing you can do about it. Sorry. It does not have Autamatic Tuning System, nor memory locations to store favorites stations. The portable Grundig/Eton such as the G5, G3, G8 have a plethora of memory locations and ATS.
Dec 28, 2010 | Grundig S350 AM/FM/SW Radio
I just bought a portable radio Grundig G8 Traveler II Digital. I would like to change the temperature display from Farenheit to Celsius. Is it possible? How could I do it? Thank you Frank Lomas
To commute from °F to °C : simply press the button labeled 9/10k for two seconds to change the medium wave station spacing from 10 KHz to 9 KHz.
May 19, 2010 | Grundig Audio Players & Recorders
Radio doesn't work at all
are you getting and static sound out of radio? and are you sure the unit isnt staying on c.d. and not switching to radio when disc is removed?
Oct 02, 2009 | Bose Wave Music System CD Shelf System
Grundig S350DL needs a am aerial to bring in the
1. run 18 gauge wire (buy in auto parts shelf), after stripping plastic (about 1/2 inch) away from wire inside. Clip where RED clip is, on back of radio. Need about 6 to 10 feet. Run wire in upwards direction from radio. At other end of wire, strip enough to make small loop back onto itself. (terminates the wire.) Run another length of same wire from BLACK clip on back of radio, strung along floor of room - 6 feet, maybe. Yes, hide it if it does not please somebody's eyes. Now, you have an AM external antenna.
2. Go to E-Bay, "slinkyantennas". They have a very good-looking, and performs for DX'ing antenna. Use same wire from RED clip, stripped, for alligator clip from 'slinky' shop's antenna to grab hold.
--With s350dl (NPR version-before major t-storm did kaputs, learned good lesson ... always use batteries, not A/C), and slinky pvc-style antenna with ground wire, was able from Central Louisiana, to pick up KOA from Denver!
Feb 28, 2009 | Grundig S350 AM/FM/SW Radio
Long wave car radio reception becomes unlistenable when engine running
Hi oldquincpie
If it is a problem that has just started, it is probably a bad earth on your antenna. If it is fender mounted, it may have dirt and rust under its base. Try loosening it off and cleaning under it with some emery tape. put it back together and try it. If you still have no luck, it may be that the antenna has a faulty internal connection. replacement may be necessary.
If the problem has always been there(since radio installed), you may need to do some radio interference suppression efforts to the car. Check the aerial first and see how you go. In the workshop, we have a spare aerial to plug into the back of the radio and temporarily earth it to the chassis somehow to check for an antenna fault.
Jul 15, 2008 | Audio Players & Recorders
Bose wave radio static only
Try replacing the battery (turn it over, have a look on the bottom there will be a door for a battery) and then trying it. Alternatively connect a aerial as it sounds like a reception problem.
Jun 01, 2008 | Bose Wave Radio II
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
