Question about Coffee Makers & Espresso Machines
The only setting for drinkable coffee, is to set for 6 cups, and adding water to 12 cup mark. is this fixable/
SOURCE: More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Posted on Jan 11, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
  • 13 Answers
SOURCE: Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Posted on Aug 28, 2009
  • 1335 Answers
SOURCE: I put in 12 cups of water and only 4 cups come out
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Posted on Nov 16, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
Sep 16, 2012 | Keurig B100 Coffee Maker
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
How does the pot make strong or reg. coffee by pressing a botton not adding coffee amount ?
By pressing the button for "stronger" coffee, it slows down the rate at which the water enters the grounds. This allows the water to set in the grounds longer and therefore can make the coffee a bit stronger. This is why on some pots when there is a 4 cup setting used, it takes longer for the coffee to be made. With such a small amount of coffee, it should go thru more slowly to get the same result.
Mar 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
I don't know how to make coffee.
The best way, if using ground coffee, 1 teaspoon per cup. Depends how big your coffee pot holds of water. So if you're planning to make coffee for 12 cups, just put in 12 teaspoons. Best Part is you can ground your own fresh ground coffee, or ground them at your Favorite Store, like Hazelnut etc.
You can buy the pouches. They make them for 4 cups 6 cups 8 cups, etc. (Like the ones they give you when you stay at the hotel). Fill the proper amount of water, for cups you're making.
My favorite are the single cups. Folgers makes them in regular and decaf. Look like tea bags, and they for 1 Medium Cup of Coffee. After you are done, just throw away.
Good Luck :0)
Nov 11, 2009 | Krups Coffee Makers & Espresso Machines
Not getting all the water
Faulty check valve inside the tubing at the bottom of the unit. This is the tubing conveying water from the outlet of the tank into the heater coil prior to going into the coffe basket.
I have the same problem but cannot find replacement check valve.
Feb 16, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
its most likely evaperating cheaper models are known for this!
Dec 09, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
