Question about Garden
Arians sno tek snowblower won't start. Changed spark plug emptied gas and used mechanic in a bottle still no start
  • 37 Answers
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Posted on Jan 28, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
40longyears
  • 296 Answers
SOURCE: the lawnmower won t start after pulling the start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Posted on Oct 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My mtd(11A-54MC552) lawnmower won't start. changed:
The Flywheel has a brake and switch assembly on that is item 8 of this link: http://www.ereplacementparts.com/mtd-11a54mc006-2009-push-walkbehind-mower-parts-c-20039_20100_133234_21459.html#part_343018
The switch is made or unmade by the position of the user safety bar on the handle. When the cable between the handle and the flywheel safety brake wears or needs adjustment the safety switch continually grounds the ignition so there is no spark. You may have to adjust the user safety bar cable at the engine flywheel brake switch area by losending the mount screw and moving the cable jacket further away from the switch. Then re-tighten the mounting screw.
If this is the first start of the season you may have to remove the carb float bowl as shown on the bottom of item 14 the above link to clean out the jet orifice in the threaded area of the carb. Make sure you remove all debris in the carb float bowl area. You should also have fuel flow anytime the float is positioned below horizontal.
If none of the above corrects the problem respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Jun 10, 2011
  • 21 Answers
SOURCE: I have the Bolens BL410 gas cultivator. It won't start. I have changed the gas and the spark plug but it won't start. I don't know what else to try
Spray starter fluid in the air filter. This should work.
Posted on Apr 09, 2012
I have an ARIEN snowblower Model 921031 24". It will not start. Please help me remedy this. Thank You ....Eddie
If there is adjusting screw on the carb open it up a part of a turn and see what happens I had to do that to my Craftsman Blower. Open is left If that does not work
Take the spark plug out and shoot a little bit of gas into the plug hole then put the plug back in. Try to start it. If it starts and stalls then try two or three times. Make sure you have fresh gas as well.
Dec 20, 2016 | Garden
Brand new. Why can't I get it to start?
Have you used the snowblower recently or is this the first time. Can you explain as to different things that you have already tried. For example Checked for spark, Fuel, plastic key is there, has the outside air temperature changed?
Remove the spark plug after you try and start it and see if the spark plug is wet with gas, if so the plug maybe fouled under compression a new plug will be required. If no gas is present on the plug, there may be some ice in the carburetor from water in the gas. This is why i had asked if there was a temperature change. A trick that I tell my customers is to warm up around the carburetor with a hair dryer or heat gun. Do not get to close remember gasoline is present.
Jan 23, 2016 | Cub Cadet Snow Blowers. 24 in. Two-Stage...
Will not go in reverse
yes adjust the linkage so the drive wheel goes past center
of the alum drive disk
Mar 03, 2014 | Ariens Sno-Tek 28 In 2-Stage Gas Snow...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Engine chugging
carb dirty
clean and put fresh gas in it
Dec 18, 2013 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
I have a 2010 49cc Tao Tao moped. I have only had it for six months. I bought carburator and jet cleaner for it called "Sea Foam" for small engines. I put the amount the bottle told me to add to...
HI,,empty your gas tank,,and drain the carb put some new fuel in the tank and dont use additives again,,some do more harm than good (especialy in 2-strokes)
Apr 20, 2011 | Husqvarna CR 250 Motorcycles
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
