Would there be a difference in the heat if you changed the psdo10bf to a more Expensive lexpro? I had a Honeywell.
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Heater got tipped over now wont heat. It lights up when I power it on the display works, no HEAT. I have 5 small grandsons that live with me and this heater was quite expensive I need it to work and...
I do believe that there should be a tip switch under the feet and if it is broke off then you need to by pass the switch. You could use a small piece of dowel rod up inside to trip the switch and have heat.
Dec 13, 2010 | Honeywell HZ519 Baseboard Heater
The usb device didn't work
Hello. When you plug in a USB device you must also download and run a disk called a driver. If you do not have a disk, you can download one. Just go to the company web site for the product and find the free downloadable driver. For example if you have a lexpro product, just google Joe
please rate my answer as very helpful. thank you.
May 01, 2010 | Computers & Internet
Honeywell ST6400C central heating programmer fault
you may vae to enter a different "Mode" to change the time....also try removing the batteries for 10 minutes and then reprogram the thermostat again
Oct 25, 2009 | Honeywell Electronic Programmable...
Heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Nov 25, 2008 | Honeywell TH4210D1005 Heater
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Hi i am working as an electrical installer and would like to know where i can access all the electrical drawings for all the different heating systems Honeywell
try this.. all honewell drawings.. in it
Nov 13, 2007 | Honeywell HFS641P Stand (Pedestal) Fan
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
