Question about Home
Just broke one of my jets on the side of the tub. How do I get another one? Larry
  • 19,031 Answers
You get one from a hot tub or spa store.
Or google
make spares
Google
Posted on Dec 30, 2016
We have gunk coming from the jets when powered on - What's the best way to clean this tub so we can actually use the jets?
You need to use them on a regular basis. Put as little water in the tub as you can get away with and then add some bleach. Run the bath jets for 15 minutes to clean and sterilise it. Empty the bath and fill it again with plain water. to rinse it.
Feb 25, 2018 | Jet Home
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
Jets breaking lose from tub
Call a repair man.
Nov 06, 2013 | Home
Have a dreamaker X-500 Only get air on one side out of my jets. Steve
Either an air line has become disconnected, or the air valve on the spa is clogged/broke.
If this is a blower model and not a venturi tee air injection system, the lines on the one side probably blew off.
Nov 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
Cleaning a whirlpool tub
The jets turn yellow from exposure to the sun, not much you can do except replace the jets (costly). What is leaking? if you broke the seal on a jet it will leak and have to be resealed.
Mar 24, 2009 | Home
Home Logo
1,664 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
