Question about Sewing Machines
My mothers touch tronic 2000 needle does not move. Everything else works fine. Lever over bobbin and made the click. Any help?
  • Sewing Machines Master
  • 11,239 Answers
If I'm correct, that is an older mechanical machine (good but probably needs some TLC). Most likely when this occurs in a machine of this age, it is because it has not been lubed for a long period of time. It is best to take care of this issue before further attempting to run the machine so the motor does not get damaged.
Following is the method I've used on several older machines that have seized. Works every time unless there are other mechanical issues involved.
Wheel on right side that controls the needle up and down is very tight...
Posted on Dec 31, 2016
Noisy Singer Touch Tronic 2010 sewing machine
the noise could be from the needle /hook timing, or bobbin carrier
take it to a service center for a service and to find out the worn/ loose parts
Dec 21, 2015 | Singer Sewing Machines
I was recently given my mother-in- law's Singer touch-tronic 2000 sewing machine. The needle bar does not work. What could the problem be. Please help me. Thank you
check with a singer service centre but some singers have a belt drive inside the case that works the needle bar mechanism
they are known to break
it is in side at the right hand end just behind the outside pulley
Jul 25, 2015 | Singer Sewing Machines
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Bobbin will not load on a singer touch-Tronic 2000
Please check the bobbin tension or you bought a new bobbin and case otherwise check the timings.
Jan 31, 2014 | Singer Sewing Machines
Ishow me how to rewind the bobbin on a touch tronic 2001 singer sewing machine
Presser foot up, takeup lever at the top, thread the machine normally all the way and through the needle, open the needle plate, press the little lever to the right, wind the thread from the needle round the presser foot screw, press on the foot control slowly and wind the bobbin, when you have enough thread on the bobbin close the slide plate the winder will drop down, pull the threads to the back of the machine and start sewing
Oct 30, 2013 | Sewing Machines
Ihavea touch tronic 621 machine the needle will not pick up the bobbin thead so i cant stitch
Try new needle first, then....look HERE for generic advice as to timing:
If over 2 years since last service, ....too long
Oct 31, 2011 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
