REPLACE TV PART IC - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Dec 31, 2016
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
Im not sure if vertical output transistors is the prob, but my tv has picture only in the middle vetically, i change the capacitor and ic, but still it didnt work out, pls help.
Hello
Your assumtion is currect. But the vertical output section of this TV has no transistors at all. It is composed of an IC. Check the soldering terminal connection of this IC legs for any loose soldering first. Just resolder all the solder terminals of this IC by applying a little more solder. In most cases this will solve the fault. If not, check all the surrounding electrolytic capacitors to this IC circuit. If found suspected, replace them. Still fault perists, replace the vertical output IC with same type and number.OK.
Aug 03, 2011 | Toshiba 32A50 32" TV
I have horizontal lines in black and white on the whole screen and tv will not turn off manually,the tv is an ilo 42 inch plasma.I only selected IBM because ilo was not listed
The problem is in the vertical section of your TV.Ethier it is loose connection or leaked capacitor or deffective vertical ic.Try to resolder first the vertical section.If did not work replace leaked capacitor around the vertical ic,then check the 12 v dc supply of vertical ic and final ok the rest is good replace vertical ic.
Jul 16, 2011 | Televison & Video
How do you adjust the vertical lines going across my screen?
The vertical deflection circuit of your tv has a problem.
First, try to replace the vertical ic. This ic can be found near the plyback or horizontal section. It is a linear ic with heatsink.
If nothing happens after replacing the ic, replace all the polarized capacitor near the ic and resolder the components at the vertical section.
Jan 18, 2011 | Durabrand BH1304D 13" TV
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
Have a GE 32GT740 32" TV.....How can I adjust the Verticle? I can only see part of the ESPN trailer line at the bottom of the screen.
the vertical deflection circuit of your tv has a problem.first try to replace the vertical ic..this ic can be found near the plyback or horizontal section It is a lenear ic with heatsinc..if nothing happens after replacing the ic ,,replace all the polarized capacitor near the ic and resolder the components at the vertical section...good luck please rate my help..
Jun 03, 2010 | GE 32GT740 32" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
IN TV i have not get a picture on av mode mean av is not switching in this tv IC 9380PS as microproccessor IC & 24c16 as memory IC
look to the IC near the AV jack there is a AV switch IC. try to replace it. but some tv use a large IC jungle which is the AV sw. is also inside that large IC.So study carefully if your tv has a separate AV sw. IC..
Jun 04, 2009 | Televison & Video
My samsung tv startup with full volume
Its memory IC is gone needs to replace check model spec or IC log book for yours model or email brand services to get IC number i.e. 8 pin ic any one with soldering knowledge can do that
Dec 25, 2008 | Samsung DLP HL-P5663W 56" TV
TV wont shut off
If you hit your tv in on/off switch panel the swicth need to replace but if you use remote control you system IC or Croma IC are defective.
Oct 13, 2007 | Sanyo DS13204 TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
