Question about Building Materials
On my genie powermax 1500 model 4062 garage door opener, the up and down limits keep changing on their own. Is there something stripped?
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
  • 31 Answers
SOURCE: Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
  • 19 Answers
SOURCE: genie garage door won't shut. the down limit
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Posted on Nov 22, 2009
  • 504 Answers
SOURCE: How do I program my Genie garage door opener to my 2005 Kia
Posted on May 26, 2010
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
Genie Powermax 1200 installed but only move approx 6 inches at a time.
You need to program the unit for up and down stops you can download the instructions from the link below
Jan 02, 2013 | Home Security
Garage door opens an inch then stops. i hit the button again and it closes. then sometimes it wont even respond. can you help me fix this through this chat
Hi and welcome to FixYa, I am Kelly.
This almost sounds like the door safety optics near the bottom of the door is not working or the optics path is blocked with something. Check the path between the 2 sensors for any obstructions. You may or may not see the red optics light path between sensors as some of these are infra red.
If the path is clear start looking at optics wiring near the sensors and all the way to the opener terminal board for any signs of damage. If all of that appears fine... then your probably going to have to replace the up/down limit switch assy.
Before you get too deep into all of the above... if the door senses a jam as in it has to drive with excessive force it will do exactly as it is now. Bent door rollers... something hanging down from the ceiling blocking door movement in the UP direction.
There really are several things that can cause this:
1. Optical sensors
2. Door limit switch
3. Force adjustment assembly
4. Blockages of optics path or door movement path
5. Stripped worm gear in the opener that has caused the door sequence timing to change on the limit switches.
6. Failed motor drive gear assembly.
Even for professionals some of these can be very time consuming to isolate and repair. (you can tie up as much money in repair labor costs as it would cost to replace the opener. Since you did not indicate how old your unit was or the exact garage door opener model number, the response above is very generic. I am not telling you to replace your opener. Only advising you of what can be high repair costs.
If your not that mechanically inclined I would call a garage door installer and ask that if he can not repair your opener what would be the replacment cost. Negotiate a diagnosis / repair cost vs replacement cost over the PHONE. Explain the symptoms and see what they say. (Call more than one before making a commitment!) Expect to hear all of the answers I mentioned above.
Thanks for choosing FixYa,
Mar 25, 2011 | Genie Company Genie Excelerator Down Limit...
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
Older garage door opener, 1/2 hp limit switch does not stop door in up position keeps trying and does not shut off?
If this is a Craftsman you need to remove the cover and you can then watch the limit switch assembly. If it is a Genie the up limit contact is probably broken
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keeps running after it is shut
to tell you how to fix this is tricky your limit switch is not working, if it is a liftmaster, or sears craftsman take the cover down, if it is a older allistar it is a dog limit on the chain, if a genie check the cherry switch in back of operator behind cover.
Mar 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
67 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
