Question about Kitchen Ranges
Creda cooker model no.48196 Main oven gets too hot perhaps the thermostat is malfuntioning
  • 19,396 Answers
If the oven is getting too hot, that means that you have a bad temperature probe in your oven. The temp probe can be tested using a multimeter, and should read about 1100 Ohms at regular temperature.
Your cooker has a temp probe on the top oven and one in the main oven.
Here the replacement for the main oven:
Stock Number: ES491324 Main Oven Thermostat
Regards.
G.
Posted on Jul 21, 2009
My creda cooker lost power when I turned on the grill but did not trip the main fuse and there is still power at the main swtch
Is it a built-in model? If it is then there is sometimes a wall plug in a cupboard that may have a fuse in it.
Feb 01, 2016 | Creda Ovens
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
My oven gets too hot. It doesn't matter what tempurature you set the oven to, it gets as hot as possible and never turns off.
def sounds like a runnawy thermostat issue, depending on age of uint, may be a bad thermostat. or the newer machines use thermistors, perhaps even a contct welded shut not allowing for proper cycling of temp
Oct 28, 2008 | Kitchen Ranges
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
