Question about Panasonic Health & Beauty
How to replace the battery in a panasonic er 389 ?
Er 398 beardtrimmer
take off the blade, loosen two philips screws, wide blade slowly remove the upper from the lower half.....replace old with new batteries
http://www.akku-wechsel.de/shop/akkus/rasierer/akku-fur-panasonic-bart-haarschneider-er-398.html
Jan 05, 2014 | Panasonic Health & Beauty
Ni Cd Batteries for ER203 Panasonic
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Aug 12, 2013 | Panasonic ER 203 Beard Trimmer
Where can I purchase a battery named VINNIC /1131 which is needed for the below calculator
Hi, Richard....
You can purchase it from amazon/ebay/aliexpress etc.. but i prefer amazon (most secure and cheap). visit this link Amazon com VINNIC 1131 and choose which one you need . (cheapest one was about 2.99$ I think). Take a look
I hope I have helped you
enjoy
Apr 06, 2012 | Office Equipment & Supplies
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
May 12, 2011 | Panasonic ER 240 Beard Trimmer
My Panasonic ER 203 with problem spring of
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Feb 14, 2010 | Panasonic ER 203 Beard Trimmer
Panasonic ER389 Trimmer Battery Pack
Hi. A Google came up with the correct battery as being either 4/5 sub-c or sub-c Ni-Cd with solder tabs. The Google hit was a bit vague on that but you will beed to disassemble it anyway so disassemble and measure the size then order the correct battery. It seems to have come with NiCd but you can replace with NiMH for better performance. This is not really a "user-replaceable batery" but it is not a big deal to solder one in. Remember to tin the tabs first. With shipping expect to pay around $8-10 for the battery. Given that and the amount of work to replace you may want to consider repacing the trimmer.
Jun 22, 2009 | Panasonic ER 389 Beard Trimmer
Opening the Panasonic ER203
just insert a thin bladed knife between the two parts and gently lever apart
Jun 04, 2009 | Panasonic ER 203 Beard Trimmer
Pansonic er200 need new rechargable battery
two AA rechargable batteries can be used, and yes you can replace them yourself.
Dec 05, 2008 | Panasonic ER 240 Beard Trimmer
Health & Beauty Logo
164 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
