Question about John Deere Garden
How do you check compression on a 2030 john Deere engine
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Mar 17, 2017
I have a john Deere 2030 that the engine will continue to run when the ignition is in the off position. What is the cause and is there an easy fix
Hi Nathan:
Have a look at the switch and see if there is a "ground " wire that has pulled off and is hanging loose.
It is also possible that the switch is broken.
Aug 30, 2015 | John Deere Garden
What makes 2030 diesel engine fire
injector pump right behind the alternator shaft driven off the front crankshaft ? why?
Nov 11, 2013 | John Deere Tractor Side Screen...
What makes my john deere 2030 diesel engine fire
Super high compression ratios in the combustion chambers which ignite a highly COMBUSTIBLE, not overly FLAMMABLE fuel mixture. How they get the mixture to fire at or before top dead center of the compression stroke I have no idea.
Nov 11, 2013 | John Deere Garden
How do you check hydrolic fluid level in a John Deere 2030?
Right side foot plate next to the rear end housing is a cap you screw off with your fingers. It has a dip stick under it.
Sep 21, 2010 | John Deere Tractor Side Screen...
I have diesel in my oil on my 2030 john deere tractor
it can be one of three problems fuel pump leaking injectoin pump or a injector over fueling
Apr 03, 2010 | John Deere Tractor Side Screen...
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
60 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
