Question about KitchenAid Refrigerators
Kitchenaid KSCS25INSS01- damper continues to try to close even when fully closed and makes noise. Diagnostic test was fine- damper opened fully during test and closed fully after test.
Slimsl
  • 108 Answers
SOURCE: setup asking me to close internet explorer when it is not open and i cant continue with instalation
Open task manger by pressing "ctrl" + "alt" + "del" and find the iexplore process and end it, then you will be able to continue.
Posted on Dec 21, 2007
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
mads_aye
  • 58 Answers
SOURCE: Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
I have a kitchenaid Superb refrigerator KSCS25INSS01 and the temps are warmer than normal.
I have a similar problem, I have the same model number, mine is too cold in the the refrigerator but has the same " whirring/click noise" .I have removed the back cover and observed the condenser fan motor cycling on and off in 10 second or so intervals. the compressor is not trying to start so my guess is the control board is bad. I was hoping you have solved your problem before I buy a $250.00 part or a new "Frig" this one is 8 years old.
Lil help?
Nov 05, 2012 | KitchenAid KSRS25IL Side by Side...
No display
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the blog798088-troubleshooting-lg-refrigerator-defrost-cycles.htm&opts=1,3,5Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
Oct 19, 2012 | LG LFX25961SB (247 cu ft) Side by Side...
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
Items in the lower refrigerator compartment arefreezing
Hi, Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controlled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment.
Take care
Jul 23, 2010 | Magic Chef CTB1922 Top Freezer...
Bottle of drinks and cans are freezing in the fridge
Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment. Let us know what you find and we can go from there.
May 20, 2010 | Refrigerators
Dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
May 16, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Damper motor runs all the time even when oven is off
Sorry for not getting to this sooner.
If you can stop the motor with just a finger, it is bad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You should check the damper switch as well, especially if the motor has been "running" more than it's supposed to.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 17, 2008 | Microwave Ovens
Kitchen Aid Refrigerator Issues
Great job on the defrost drain fix, it's exactly what we do. Check that the duct damper does close fully when the refer side temps are set to warmest. It could be freezing due to that damper not closing fully or at all. It should only be open to let cold air in until the temp is satisfied then closes again. The temp control in the refer may also be failed so it doesn't know the temp was reached. The bi-metal is only there for a safety device basically to kill power to the heat elements if the defrost cycle runs too long or the area gets too hot. I'd suspect the air damper is stuck open and contstantly letting cold air into the refer side.
Feb 03, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
24 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
